Time for a new alternator? Questions.
Old May 21, 2003 | 09:04 PM
L4NDO's Avatar
Default Time for a new alternator? Questions.
Today my car would not start up. There is a fresh new batterey that I purchased about 1 month ago. Here is what my run down of the problem that led me to think it's the alternator that is bad (and I want to see if I am correct).
*Battery = dead / will not start with jumper cables and I recharged it at a shop, placed it back into the car and still nothing happened
* Will not start from a roll + clutch pop
*Interior lights and all electrical things completely off
*Car will not click when starting
*Fuses all fine
*Battery lines to the battery are clean no corrosion
When the car is on the 1st click turn of the ignition I can press the horn and hazzard lights but they just make a clickclickclickclickclickclickclick sound. So has my alternator blew on me? Opinions greatly appricated. Thanks.
Old May 21, 2003 | 11:51 PM
blueeg's Avatar
Default Re: Time for a new alternator? Questions. (L4NDO)
u recharged the battery, put it back in the car and still nothing happened? with a fully charged 12.6 volts battery that thing should start even with a bad alternator. u just wont last that long.
OTHER parts of what u said does suggest a problem with the charging systerm.
Old May 22, 2003 | 10:50 AM
L4NDO's Avatar
Default Re: Time for a new alternator? Questions. (blueeg)
bump
Old May 22, 2003 | 10:52 AM
=GAME='s Avatar
when the cars is on unhook your battery. if the car still runs your alternator is good.
edit: i dont think you can recharge a battery. i think its your battery since your interior lights or horn doesnt work
Old May 22, 2003 | 11:31 AM
igone916's Avatar
Default Re: Time for a new alternator? Questions. (GAMEOVER 1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GAMEOVER 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">when the cars is on unhook your battery. if the car still runs your alternator is good.
edit: i dont think you can recharge a battery. i think its your battery since your interior lights or horn doesnt work</TD></TR></TABLE>
First do what he just say and if the cars dies, I'm pretty sure its you alternator...You can also open your alternator and check the brush (I don't know what it is really call) and check if to see if you need to replace it...That is all Kragen, Autozone, and all parts store do to the rebuilt alternator, they replace the brush...You can pick up another brush for about $20 or less at the dealer...thats all I did and it saved me a lot of money...
Old May 22, 2003 | 11:39 AM
EH339's Avatar
Did your battery charge light ever light up on your dash? It's probably your alternator, but once my car was dead to even a jump start and it was because my <U>main</U> fuse had blown.
Old May 22, 2003 | 12:32 PM
B.'s Avatar
B.
400 HP Club
i have a 00 sir altanator f/s if you need one. IM me if interested.
Old May 22, 2003 | 04:18 PM
L4NDO's Avatar
Default Re: (THE B)
Well I checked out my car again. I tested the voltage with a tool that lets you see if electricity is running through it (I don't know what the tool is called) and my battery grounds and fuses were fine. Even the battery was shooting out power. My uncle said a loose connection in the wires might be possible. Like one of you said my battery might have not any more life in it, but with a jump start shouldn't it start? I know its an electrical problem, it's just hard to narrow it down.
* Also with the car just left w/o the key in the ignition my radio light still blinks. Plus when a door is open with key just in the ignition the beep beep beeping is going on.
How can I check my car computer to give me a CEL code? But without electrical power would it even work?
Old May 22, 2003 | 06:30 PM
L4NDO's Avatar
Default Re: (L4NDO)
Could any of the wiring be burnt?
92civic_hatch
Feb 6, 2009 06:02 PM
disposable
Jun 26, 2008 08:02 PM
boostedjdmdc2
Jun 18, 2008 04:10 PM
lawlerlaw
Jan 8, 2005 02:12 AM
EJK
Feb 4, 2003 08:03 PM
