calling all axel experts!
Old May 21, 2003 | 05:06 PM
xXx Justin xXx's Avatar
Default calling all axel experts!
ok. will 92-98 civic w/ abs axels work in my 94 cx w/ z6 and 98 ex tranny?
i bought some outter hubs for a 97 civic ex. had same # of teeth as the cx.so i dont think the cx -> dx -> ex matters as far as splines...
but what is the difference in the driver side axel from civics with abs compared to non abs. thanks
Old May 21, 2003 | 05:11 PM
SpoonFedHatch's Avatar
no difference in axle dimensions.....the only difference in appearance is that the ABS axle has a "ring tooth gear" on the hub end......
in other words, it will work
Old May 21, 2003 | 06:49 PM
Default Re: (SpoonFedHatch)
ok sweet. the outter axel spline count is 26 teeth. the inner is? inside the EX tranny. where the teeth or splines are ... in a triangle location .. there are 3 smooth spots on each side. like one tooth was filed down. but in a perfect triangle. obviously not broken. are the axels supposed to match that design where they enter the tranny? thanks alot. i am finally getting this swap worked out!
and one more thing. will the axel seal from my 94 cx 5spd tranny work for a 98 ex 5spd tranny? i have the cx sitting around, no time during the day to get to honda for a seal...but one needs to be replaced on the ex. lmk if they are swapable. thanks
SL!M
Nov 2, 2005 07:17 AM
comptechgsr
Dec 14, 2003 03:28 AM
xXx Justin xXx
28
May 21, 2003 06:46 AM
ej1civic
Apr 23, 2003 08:26 PM
blism
Aug 29, 2001 02:18 PM
