is 550cc rc saturated injectors good for boosting at 6-10 psi??
i am about to buy 550cc injectors good for stock internal boost at 6-10psi on a 2000 GSR...i wanted to know if that is too much fuel or will it be ok...thanks let me know
uhhh, you're using fuel management right...that's exactly what it does "manage the fuel"also it depends on the hp #'s mostly, compared to the psi you'll be running, 550's should get you 350-400whp range.
naw i am goin to use a safc hack and a 255lp fuel pump but not fmu ...i was rangin about 260-280whp... i think these injectors r goin to be 2much...shud i go with 440cc instead?
Save your $$ on the RC's. IM viren, hes selling delphi 550's for 200a set. Thats prob what your paying for 1 RC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civicEX »</TD></TR><TR><TD CLASS="quote">
also it depends on the hp #'s mostly, compared to the psi you'll be running, 550's should get you 350-400whp range.</TD></TR></TABLE>unless using an FMU, with which 440s can get you 450-475 WHP
uhhh, you're using fuel management right...that's exactly what it does "manage the fuel"also it depends on the hp #'s mostly, compared to the psi you'll be running, 550's should get you 350-400whp range.</TD></TR></TABLE>unless using an FMU, with which 440s can get you 450-475 WHP
but i can run 550cc with 6psi and it will be fine? cuz i dont wanna screw up my motor by gettin too much fuel in there...some1 told me it will mess my motor up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adhana2 »</TD></TR><TR><TD CLASS="quote">but i can run 550cc with 6psi and it will be fine? cuz i dont wanna screw up my motor by gettin too much fuel in there...some1 told me it will mess my motor up</TD></TR></TABLE>
of course, you just need to limit the % duty cycle
oh aite thatz tight... cuz i am gettin a badass deal on the 550's...thanks 4 all the help? reely helped me out
B_1_8_hatch
Sep 12, 2003 11:23 AM
