obd 2 differences??????
Old May 21, 2003 | 04:43 PM
svtec's Avatar
L D E S
Default obd 2 differences??????
did a search and failed to turn anything up...
i was wondering if you can run a 1996 p72 on 2001 gsr?
are there any differences? like v1 and v2.
i have a 1996 ecu and my friend bought an auction car (01 gsr) and wanted to know if the ecu would work.
thanks...
-andrew
Old May 21, 2003 | 06:25 PM
RiceNmotioN's Avatar
Default Re: obd 2 differences?????? (svtec)
96-98 ECUs use harness plugs A,C and D. 99-01 ECUs use connectors A, B, C or it was vis-versa. 00-01 came with a diasabling device. you may be better off going to OBD1.
Old May 21, 2003 | 10:10 PM
svtec's Avatar
L D E S
Default Re: obd 2 differences?????? (RiceNmotioN)
so could you use the 96 in a 01?
i mean so can you plug it in just temporarily?
<<<<<< i'm stupid
Old May 21, 2003 | 11:49 PM
acuracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">so could you use the 96 in a 01?
&lt;&lt;&lt;&lt;&lt;&lt; i'm stupid </TD></TR></TABLE>
96-99 are known as OBDIIa. 00-up is known as OBDIIb. The plugs are a little different. You won't be able to plug the ECU in.
FSBxtreme
Oct 14, 2008 02:07 PM
esoterEK..
Apr 8, 2004 08:35 AM
Type Wah
Nov 26, 2003 11:23 AM
wannakno
Jul 21, 2003 09:19 AM
-Darren-
Jun 26, 2002 08:42 AM
