code 14???
Old May 21, 2003 | 03:57 PM
lowcivex's Avatar
Default code 14???
i got a gsr in a 98 civic it is throwing a code 14.
how can i fix it??? it is an obd1 p28 ecu
Old May 21, 2003 | 04:04 PM
agturbo's Avatar
Default Re: code 14??? (lowcivex)
I think thats the idle air control valve..
Old May 21, 2003 | 08:12 PM
3rdGteg's Avatar
Default Re: code 14??? (agturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agturbo &raquo;</TD></TR><TR><TD CLASS="quote">I think thats the idle air control valve..</TD></TR></TABLE>try pulling it off and cleaning it. also check for loose connection at the iacv. is ur idle erratic at all?
Old May 21, 2003 | 08:26 PM
HondaD15BtoB16A's Avatar
I'm sorry, but I don't know what a code 14 is, please enlighten me.
Old May 22, 2003 | 08:20 AM
lowcivex's Avatar
Default Re: code 14??? (3rdGteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">try pulling it off and cleaning it. also check for loose connection at the iacv. is ur idle erratic at all? </TD></TR></TABLE>
it is only erratic when it is cold (when i first start it)
Old May 22, 2003 | 08:25 AM
wickedEFguy's Avatar
code 14 - IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
are you having a irratic idle like it goes up and down? Take the IAC off and clean it with brake cleaner and let it drive out, then just plug it in and reset your ECU. that should correct your problem
Old May 22, 2003 | 08:43 AM
lsvtec101's Avatar
Default Re: code 14??? (Ninja_Jc7)
im having the same problem, i thought it was my iac but it wasnt i bought a brand new one, and i still get a code 14? i was like wtf what POS, btw i have a OBDII, i have NO eraatic idle's, she just needs to be warmmed up by me when its cold out
so why would i get a IAC check engine light when it has nothing to do with the IAC???????? can someone answer this thanks
Old May 22, 2003 | 09:16 AM
3rdGteg's Avatar
Default Re: code 14??? (aemcivic_02917)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemcivic_02917 &raquo;</TD></TR><TR><TD CLASS="quote">im having the same problem, i thought it was my iac but it wasnt i bought a brand new one, and i still get a code 14? i was like wtf what POS, btw i have a OBDII, i have NO eraatic idle's, she just needs to be warmmed up by me when its cold out
</TD></TR></TABLE>could be that ur wiring to the iacv or ecm is not properly connected (has an open).
ksportizzy12
Aug 29, 2014 06:28 AM
ic108
Oct 31, 2002 04:54 PM
JSpecwest
Dec 27, 2001 11:08 AM
JSpecwest
Dec 27, 2001 10:54 AM
