Cant get the "silencer" out of my Apexi-N1 HELP!
Old May 21, 2003 | 04:11 AM
TegLove's Avatar
Default Cant get the "silencer" out of my Apexi-N1 HELP!
I have had the exhaust on for a couple weeks now, one of which the car was in the body shop so it was being driven. Now i cant get the "silencer" out of the muffler....any ideas how. I got the lil allen key bolt out but it wont budge.
Old May 21, 2003 | 04:55 AM
ZEXGS-R's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (TegLove)
I had the same problem. If you arn't going to use the silencer again take a pair of vice grips and clamp them on to the silencer. Then hit the vice grips with a hammer and it will come out. This is how i did it. Just an FYI, i gained 8 hp on the dyno by removing the silencer.
Old May 21, 2003 | 05:04 AM
dip-set's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (ZEXGS-R)
alicia thats not a silencer thats the banana i put in your tailpipe...
Old May 21, 2003 | 05:48 AM
TegLove's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (teg-your-it)
oh now you are putting banannas in it huh? lol .
and i cant get a pair of vise grips on it ......ive tried its in there too tight.....i couldnt even get a damn tooth pick in between the silencer and the muffler
Old May 21, 2003 | 05:53 AM
IntEGNYC's Avatar
BZZZ bZZZZZZZZZZZZ
Dremel baby
Old May 21, 2003 | 05:55 AM
TypeGSR196's Avatar
play w/ it, side to side believe me it will budge, the same thing happen to me.
u will get your hands dirty though
Old May 21, 2003 | 06:09 AM
TegLove's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (TypeGSR196)
i always end up dirty workin on this damn thing!.....im not worried....im not a lil sissy girl lol
Old May 21, 2003 | 06:21 AM
pr0jektdc2's Avatar
hmm have u tried spraying WD-40 around it? just a thought...
Old May 21, 2003 | 06:34 AM
TurboedGSR's Avatar
i'll buy it off you once you get it off
Old May 21, 2003 | 06:36 AM
MugenGTR's Avatar
jus pliers or a vise grip and grab on the inner pipe and pull that lil biitch out! works all the time!
Old May 21, 2003 | 06:51 AM
10K2HVN's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (MugenGTR)
..or maybe she light an M80 then stuff it in the little pipe and the whole thing should come apart..!
k, time for me to go back to sleep..im starting sprack-out a little.....
Old May 21, 2003 | 08:15 AM
TegLove's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (TurboedGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboedGSR &raquo;</TD></TR><TR><TD CLASS="quote">i'll buy it off you once you get it off</TD></TR></TABLE>
buy my stupid little black thing?.......if the damn thing ever comes off.....i will throw it to you!
and its in there too tight i cant get pliers on it!!!!!!!
Old May 21, 2003 | 08:28 AM
PM-Performance's Avatar
get something in there to pull on it , try vice grips, or needlenose pliers.
also if you notice where it bolts in there is an empty hole now , stick something in there and try to carefully pry that bitch out , if you mess it up i have an extra one , i will part with for a few bucks, i never used mine, they suck
Old May 21, 2003 | 08:55 AM
TurboedGSR's Avatar
far throw to tx but ok
seriously i need a silencer. 3" piping, no cat, and only one resonator=bacon
you can try pulling it with two hooks or bent rods. just stick them in the opening until they reach the end of the pipe and pull out.
itr what's the diameter on the silencer you have?
Old May 21, 2003 | 09:03 AM
WiggiE's Avatar
New User
https://honda-tech.com/zerothread?id=482772
https://honda-tech.com/zerothread?id=457622
https://honda-tech.com/zerothread?id=239438
https://honda-tech.com/zerothread?id=141580
Don't worry quite a few people have had this problem.
My suggestion is to start the car and continually pull on the silencer as the exhaust is warming up. The exhaust should heat up a little quicker than the silencer and it should come right out.
Old May 21, 2003 | 09:04 AM
2.5 i never replaced my exhaust when i went turbo , no need i got an evutout , so i just open her up
Old May 21, 2003 | 02:35 PM
Turbo Powa's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (itr206)
If you didnt get it off yet, try using pliers and pull on it. Also, do this while the car is on. rev it up alittle or drive around for like 20 minutes untill the exhaust gets hot. Then you keep tugging at it and eventually it will budge alittle. Keep pulling and pulling and BAM! it will come right off. Took me about 15 minutes to get off not including the 20 mins of driving around.
Old May 21, 2003 | 05:09 PM
Aaron M's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (Panda EK)
fondle it
be gentle
Old Jul 11, 2003 | 03:54 AM
TegLove's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (SilverB18C1)
WEll I got it out FINALLY!!......not only is it much louder but.....I took it to the track and ran a 15.7 so it knocked off some serious time! Im much happier now!
Old Jul 11, 2003 | 04:39 AM
good job, i noticed a huge diff when i tried mine that one time , and the sound was cut in 1/2 with mine though
Old Jul 11, 2003 | 04:40 AM
dip-set's Avatar
congrats ...big difference now huh..holla at ya boy..1
Old Jul 11, 2003 | 08:38 AM
Aaron M's Avatar
did it really take you a month and a half to take it out?
Old Jul 11, 2003 | 09:36 AM
romeo619romeo's Avatar
hard to find those non sissy girls...!@ that can actually drive and look good all in one....i prolly only saw 1 in my life.. and it happend to be a girl in a 2001 ITR oh how i dreamed of a girl liek that
Old Jul 11, 2003 | 09:53 AM
2qwik2nv's Avatar
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (romeo619romeo)
My wife's just like that too, knows how to drive the 'R' properly, and is learning the dirty side more and more.
Old Jul 11, 2003 | 09:54 AM
Default Re: Cant get the "silencer" out of my Apexi-N1 HELP! (2qwik2nv)
thats nice.. now go away .. stop making me jealous j/p
hamadiscool
Jun 1, 2006 08:38 PM
Kyles ej1
Jul 21, 2004 02:24 PM
JDMlyfestyle
12
Feb 28, 2004 12:32 AM
DRKSol
Dec 20, 2003 07:20 AM
crossedover
Nov 16, 2003 01:35 PM
