Cams for B20B VTEC (Normally Aspirated)
Old May 20, 2003 | 08:31 PM
turbopanda's Avatar
Default Cams for B20B VTEC (Normally Aspirated)
Just wanted to ask my FI friends here what their opinions are on cams. I'm looking into buying a set for my teg, something so aggressive that its on the limits of not being streetable/daily driven. What do you guys recommend. My head is fully built - although I need to find another head since this one was set for turbo - running a little sluggish in NA mode. Thanks
Old May 20, 2003 | 08:35 PM
JunIntegra's Avatar
Default Re: Cams for B20B VTEC (turbopanda)
wrong forum but jun 3's, toda b's and skunk2 2's are pretty sick grinds.....now get the hell outta here!
Old May 20, 2003 | 10:24 PM
Mr. Softee's Avatar
Default Re: Cams for B20B VTEC (JunIntegra)
j 3s.
Old May 21, 2003 | 12:58 AM
KOTSEMOTO's Avatar
Jun 4's Toda D's Vtec Killers Crower 413's
Old May 21, 2003 | 06:27 PM
Quick 200k Mile Motor's Avatar
Extreme lift wears out the LMA's fast.
I say go with Jun 3, lots of duration instead of lift.
Use ITR LMA's.
Old May 21, 2003 | 07:18 PM
Ivan's Avatar
senior gold member
aren't you running typer cams? Whats gonna hurt you if you get cams is the low compression.
Old May 21, 2003 | 07:20 PM
InfamousRS's Avatar
Default Re: Cams for B20B VTEC (Ivan)
http://www.ef-1.com
Rocket has some VERY aggressive n/a cams!!!
Old May 21, 2003 | 07:40 PM
bottlefedb18c1's Avatar
Default Re: Cams for B20B VTEC (InfamousRS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InfamousRS &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ef-1.com
Rocket has some VERY aggressive n/a cams!!!</TD></TR></TABLE>
thats is what i was about to say but it is hard to get ahold of him
Old May 21, 2003 | 08:33 PM
Rob Dizzle's Avatar
Default Re: Cams for B20B VTEC (bottlefedb18c1)
what do you need to know?
robert is beyond busy, but we are trying to make it so you have someone to get a hold of 24/7. within the next month it will be that way, or close to it.
ef-1 is desinging new lma's with stiffer springs for running some crazy lift & duration cams
if you dont mind a bumpy idle, than most all cams are "streetable"
Old May 21, 2003 | 08:41 PM
InfamousRS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottlefedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">
thats is what i was about to say but it is hard to get ahold of him</TD></TR></TABLE>
Give him a call...he almost always answers when I call him...if he doens't, I leave a message on his voice mail and he gets back to me very quickly!
Old May 21, 2003 | 11:21 PM
turbopanda's Avatar
I've been told to get Toda C's (http://todaracing.com/products/honda...camshafts.html) - any good?
Also, i'm already running crower valvesprings and retainers with ferrea SS valves and AEM trutime camgears, but the toda spec B and spec C cams specify that you must use toda valve springs and toda cam gears. Can't I just use my existing stuff? And I think i'm gonna need some 84.25 or 84.5mm high compression forged pistons with some forged B20B rods - any help on this?
Old May 22, 2003 | 07:39 AM
Scott - 93HB Si's Avatar
I went with 12.5 pistons on eagle rods in my B20 all motor. I have a set of Toda Spec B's (cuz i got a killer deal on them), just waiting for my toda springs to arrive now.
If you want a killer cam go with spec C's, they have the same idle/midrange power as the B's, but have more top end! they do chew up timing belts so either get the Toda Timing belt or the PE one. I wouldn't chance running anything but toda spings with those cams, although some people have had good experience with portflow/ITR combos: http://godspeed.hack.net/todafaq.html
HTH
Old May 23, 2003 | 03:34 AM
turbopanda's Avatar
Default Re: Cams for B20B VTEC (Scott - 93HB Si)
What do you rev up to? Give me some specs of your engine, i'm very intersted in your setup!
Old May 23, 2003 | 05:59 AM
check PM.
This forum really isn't the place for this topic.
Cyber ITR
Jan 10, 2006 08:02 PM
s2kboii
Honda S2000
Aug 9, 2005 07:12 AM
EgRedSi
30
Mar 11, 2005 11:49 PM
Outkast_CL9
Feb 21, 2004 12:25 AM
crazydude75927
44
Aug 1, 2003 10:05 AM
