How to read a Fuel/spark map??????
Old May 20, 2003 | 08:09 PM
boosted_zc's Avatar
Default How to read a Fuel/spark map??????
I recently got my Zdyne, loaded up the software, uploaded a stock program onto it and........ what the FAUK do all these #'s mean. Obviously the vertical column is RPM's but what does the horizontal column mean. Gimme some help here. Thanks
Old May 20, 2003 | 11:10 PM
_Endless_'s Avatar
Default Re: How to read a Fuel/spark map?????? (boosted_zc)
i like to know also so bump.
Old May 21, 2003 | 01:45 AM
7PSI CRX's Avatar
Default Re: How to read a Fuel/spark map?????? (_Endless_)
The rows running across the top are intake manifold vacuum/pressure. 30"HG - ?PSI
(Engine load)
Old May 21, 2003 | 02:15 PM
boosted_zc's Avatar
Default Re: How to read a Fuel/spark map?????? (7PSI CRX)
Ok so know that we have that first part settled, then what do the #'s specify on each one. I'm guessing the fuel map one is volume, but in what measuement is it in. And in the spark map, what do those #'s represent. Thanks again
Old May 21, 2003 | 02:49 PM
7PSI CRX's Avatar
On the Fuel Chart, the #s represent "injector pulse", in Milliseconds.
On the Timing Chart, the #s represent "Ignition Timing", in degrees, before top dead Center. (BTDC)
Is that what you wanted to know, or are you trying to figure out what the vacuum #s mean?
Old May 21, 2003 | 06:06 PM
boosted_zc's Avatar
Actually that first part answers it perfectly, it's starting to click in my little brain now. What i'm still wondering is what #inHcr stands for (# being any given numberin the maps) then it goes to lb which is obviously pounds. But how to you tell if it's vacuum or pressure. Or in the case of a NA engine is it all vacuum. My engine is gonna be turbo'd so how do i interpret these #'s in that application. Sorry i ask so many questions, but i like to thoroughly understand concepts i have lacking knowledge in. Thanks
Old May 21, 2003 | 09:18 PM
Scott_Tucker's Avatar
Are the numbers in Hex or are they decimal?
Old May 21, 2003 | 11:41 PM
7PSI CRX's Avatar
Default Re: (AutoEng2002Si)
Now it all comes clear.
I take it you don't have a gauge yet. Get one.
Old May 22, 2003 | 04:54 PM
boosted_zc's Avatar
Default Re: (7PSI CRX)
Actually i don't have my guages yet, hell i don't even have my block back yet. But actually on your gauge it says Hg not Hcr, i'm guessing it represents that same thing, but what does it stand for?
Old May 22, 2003 | 05:09 PM
boosted_zc's Avatar
Default Re: (boosted_zc)
here we go, pictures always help. This is a stock PM7 ecu program
Old May 23, 2003 | 12:38 AM
7PSI CRX's Avatar
That DOES SAY HG, not Hcr.
There are many ways to measure vacuum, and many different dial scales for any said gauge.
HG is one of the most common.
HG = "inches of mercury"
Old May 24, 2003 | 08:49 AM
boosted_zc's Avatar
Actually it DOES say Hcr, it's just a bid pic. But that really doesn't matter, im sure it means the same thing.
Old May 25, 2003 | 08:58 AM
boosted_zc's Avatar
come on all of you brainiacs, i know there is more info out there for me.Share with me your vast knowledge o wise ones.
svacca1
Nov 20, 2007 11:16 PM
thewrai6th
Oct 23, 2007 07:10 PM
Shft@9GSR
Dec 12, 2002 09:56 AM
xci_ed6
May 20, 2002 05:45 AM
