gaining Oil?
Old May 20, 2003 | 05:36 PM
G3gsr's Avatar
Default gaining Oil?
my oil looked over yesterday so today i decided to leak some out! then later i took it out for a drive probably for 30 minutes! then waited 1 hour and checked the dip stick i gained it all back! first i thought o crap maybe i have a bad head gasket, but im not really seeing any loss of coolant, or white smoke, or milkshake on the dip stick! Maybe its just because its still hot and the oil is expanding! im using mobil 1 full syn 10-30!
Old May 20, 2003 | 06:37 PM
ejprimo's Avatar
Default Re: gaining Oil? (G3gsr)
to get an accurate reading on your oil level, check when the motor is cold.
Old May 20, 2003 | 07:11 PM
mugenracer's Avatar
Default Re: gaining Oil? (ejprimo)
check when cold and always check with the car parked in the exact same place. I have checked my car in two different places at the front of my house (within 12 feet of each other...my house is built on what i would call near dead level) and found almost 1/4" difference on the dipstick, but when i moved the car back to the original spot, and let it settle again, i found no difference in levels
Old May 21, 2003 | 05:54 AM
JimBlake's Avatar
Default Re: gaining Oil? (mugenracer)
Yeah - garages & driveways are NEVER perfectly level. If they were, water wouldn't drain off.
Old May 21, 2003 | 02:40 PM
G3gsr's Avatar
Default Re: gaining Oil? (JimBlake)
i moved it to the same place it gained 1/4 again? could it be a fault valve cover gasket? i took my valve cover off a few times recently!
Old May 21, 2003 | 07:14 PM
4DeepCivic's Avatar
Oil splashes all over the place in your engine. It has nooks and crannies. Check it when it had sufficient time to cool down both times..
Old May 21, 2003 | 07:26 PM
G3gsr's Avatar
Default Re: gaining Oil? (4DeepCivic)
it doesnt really have the symptoms of a blown headgaket! iono if it can be my oil filter or not havent changed in a while! or a seal?
Old May 21, 2003 | 09:13 PM
Scott_Tucker's Avatar
If your engine is running excessively rich fuel dropout on the cylinder walls will pass the rings and allow raw gasoline into your crankcase.
Old May 22, 2003 | 04:22 AM
JimBlake's Avatar
Default Re: (AutoEng2002Si)
If gasoline is getting into the oil then the oil would smell like gas. (G3GSR: Does it?) In any case, having the oil analyzed will certainly show whether this is happening.
But if it keeps 'gaining' oil, there's not many places for it to come from. Coolant getting in there will be obvious because it looks so much different.
Old May 22, 2003 | 02:35 PM
G3gsr's Avatar
Default Re: (JimBlake)
it kinda smells like fuel but im not completely sure! dis happens if u run too rich?
Old May 22, 2003 | 03:20 PM
Sure, if you're running too rich the extra fuel will cling to the (relatively) cool cylinder walls and get past the rings and into the crankcase. If your oil level is going up really fast then it must be running extremely rich. You could pull your plugs and look for black, sooty deposits on them or have someone stick a sniffer in the tailpipe and see how much CO its putting out.
One thing is for certain: some fluid is getting into your oil. If you are not losing coolant then really the only other thing it could be is fuel.
fackyou
Jul 7, 2006 12:24 AM
Bond
20
Nov 2, 2005 03:12 PM
gooberwolf
Aug 18, 2003 09:35 AM
G3gsr
May 20, 2003 06:17 PM
