could i do this for a compression test?
Old May 20, 2003 | 04:43 PM
JunIntegra's Avatar
Default could i do this for a compression test?
well heres what i know so far for a compression test:
pull ecu fuse
take out ALL spark plugs at once and check each cylinder
turn key to crank over 4 times on each cylinder.
would i have to hit the gas pedal at all? thats what somone said
this is what ive gotten out of the search so far. i know i dont have everything down so please help so i can do this right
Old May 20, 2003 | 04:52 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: could i do this for a compression test? (JunIntegra)
yes you should hold the throttle wide open while turning the engine over.
Old May 20, 2003 | 04:57 PM
Kamin's Avatar
Default Re: could i do this for a compression test? (fastcrxsi90)
yeppers
Old May 21, 2003 | 05:28 AM
JimBlake's Avatar
Default Re: could i do this for a compression test? (Kamin)
Keep cranking until the gauge isn't increasing any more. 4 is about right, but that's not an absolute rule.
Old May 21, 2003 | 05:51 AM
4DeepCivic's Avatar
Default Re: could i do this for a compression test? (JimBlake)
I concur.
Old May 21, 2003 | 07:01 AM
blah13's Avatar
Default Re: could i do this for a compression test? (4DeepCivic)
Also make sure your car is at operating temp b4 you do the test...dont want to be doing 20-25 cold cranks
Old May 21, 2003 | 07:14 AM
Eluzion's Avatar
Just don't use the piece of junk compression tester for $15 from Harbor Freight. I regret buying it... not only does it fail to work correctly (doesn't seem to tighten to the spark plug hole enough, so you lose a ton of pressure when doing the test), but the adapter piece got stuck down in the spark plug hole once... had to buy some loooooooooooonnnnnggggg needle nose pliers to get it out. Luckily I didn't tighten it that much or else I don't know what I would have done (the socket that fits it doesn't fit the spark plug hole). The one from Schucks with the steel braided hose looks nice.
Anyways... yeah... enough of that. What everyone else said is pretty much all there is to it...
Old May 21, 2003 | 04:06 PM
JunIntegra's Avatar
Default Re: could i do this for a compression test? (Eluzion)
thanx guys. i was told that i need to regap the plugs after the test. is this necissary? there boschx4's. they come pre-gapped. does this have to be done to spec again?
Old May 21, 2003 | 06:28 PM
GSpeedR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunIntegra &raquo;</TD></TR><TR><TD CLASS="quote"> thanx guys. i was told that i need to regap the plugs after the test. is this necissary? there boschx4's. they come pre-gapped. does this have to be done to spec again?</TD></TR></TABLE>
Might as well check when they are out.
Old May 22, 2003 | 04:12 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunIntegra &raquo;</TD></TR><TR><TD CLASS="quote">... there boschx4's. they come pre-gapped. does this have to be done to spec again?</TD></TR></TABLE>
Bosch Pt+4 have a strange gap, cause they use some kind of surface-arc. I don't know if the gap is supposed to be the same as normal plugs. Besides, the center electrode has that ceramic collar around it, so its hard to measure the real gap...
integraRS-T
Jul 3, 2007 10:39 AM
iHOPEyouCHOKE
Apr 27, 2006 04:44 PM
zracer240
Apr 24, 2005 08:35 AM
Traction
Apr 6, 2004 06:11 PM
comptechgsr
May 28, 2002 12:34 AM
