lotus side draft carbs??
Old May 20, 2003 | 01:32 PM
civic disobedience's Avatar
Default lotus side draft carbs??
anyone know anything about side draft carbs?
was at the junkyard looking for turbos and came across a Lotus with dual side drafts on it!!
are they good carbs? worth anything??
I was going to take them but not sure if it is worth it... I did not ask how much they wanted for them, but they let stuff go pretty cheap... I grabbed a laser (DSM) turbo and side mount IC for $60 (and the turbo is good too)
anyone offer any info/advise??
Old May 20, 2003 | 02:25 PM
dfoxengr's Avatar
Default Re: lotus side draft carbs?? (civic disobedience)
go take some pics and send the to me, ill fab up some ghetto ITBs to try out...
Old May 20, 2003 | 02:34 PM
Default Re: lotus side draft carbs?? (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">go take some pics and send the to me, ill fab up some ghetto ITBs to try out... </TD></TR></TABLE>
might work, if you can weld, and machine for injectors... they are pretty big, gotta be 50mm of close to it...
going to search some more tomorow when I have more time... only found cars for sale so far, not much in the way of parts
Old May 20, 2003 | 05:25 PM
SOHCwarrior's Avatar
thats gonna be hard to fab up ghetto ITB's with carbs
Old May 20, 2003 | 06:07 PM
dfoxengr's Avatar
Default Re: lotus side draft carbs?? (SOHCwarrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCwarrior &raquo;</TD></TR><TR><TD CLASS="quote">
thats gonna be hard to fab up ghetto ITB's with carbs</TD></TR></TABLE>
no its not, theyre relatively the same as ITBs. both are stacks..blah blah, youve seen motorcycle ones on dseries...
Old May 20, 2003 | 06:08 PM
dfoxengr's Avatar
heres some now
https://honda-tech.com/zerothread?id=391378
Old May 20, 2003 | 07:06 PM
no its not, theyre relatively the same as ITBs. both are stacks..blah blah, youve seen motorcycle ones on dseries...</TD></TR></TABLE>
they are two different animals and function completely different
Old May 21, 2003 | 02:25 AM
they are two different animals and function completely different</TD></TR></TABLE>
they are completely different... carbs are mechanical, injection is electronic (for the most part anyway)
if you really think you have some skills, then cut the front part (inlet and plates) and weld/attach it to some tubes, and weld it to a flange, and machine out holes for the injectors... you would need some good machineing equipment .
if I had the tools, and the time I would try it...
or just learn to tune carbs
Old May 21, 2003 | 02:32 AM
well... I guess I will go back and grab them... they should be pretty cheap, and even if I dont sell them, I will just throw them in a box.... when I am an old man with nothing to do I can mess around with them
unless someone wants them... I will not mark up much
Modified by civic disobedience at 7:48 AM 5/21/2003
Old May 21, 2003 | 03:02 AM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic disobedience &raquo;</TD></TR><TR><TD CLASS="quote">
or just learn to tune carbs </TD></TR></TABLE>
that was the original idea, not to utilize carb injection but retain fuel injection
Old May 21, 2003 | 07:59 AM
94CivicSi's Avatar
throw them on ebay. My Dad dug up a bunch of old hot rod stuff that's been sitting in his garage for about, oh 25 years or so and made a MINT! A magneto for a flathead Ford that didn't even work went for $1200. SOMEONE is looking for stuff like this.
KRAP DIVAD
Jun 12, 2007 09:52 PM
SLOENUF
Oct 4, 2006 08:36 AM
Humble Performance
Aug 23, 2006 07:02 AM
wrx'n you
Jul 24, 2005 01:29 AM
wrXtian
Apr 23, 2003 08:39 PM
