What does the flywheel bolt to?
Old May 20, 2003 | 12:52 PM
Specialk's Avatar
Default What does the flywheel bolt to?
Just like the title says, i just picked up a flywheel for my 5spd LS tranny, im doin a auto to 5spd conversion, so i dont know too much about the tranny but i was lookin at it and there doesnt look like theres any place for the flywheel to bolt up. so im wondering what piece do i need to get to mount the flywheel. im so close, i hate my damned automatic. thanks.
Old May 20, 2003 | 01:31 PM
JimBlake's Avatar
Default Re: What does the flywheel bolt to? (Specialk)
The flywheel bolts to the crankshaft.
Old May 20, 2003 | 01:58 PM
madslackin's Avatar
Flywheel bolts to the crank like he said. You won't see where it bolts until you remove your transmission.
Also, when you bolt the flywheel on you should get new bolts. Flywheel bolts are longer than the flexplate bolts you have now. The bolts you'll see will say "AT" on head and the correct bolts (you can get them from the dealer) will say "MT" on them.
Justin
Old May 20, 2003 | 03:41 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What does the flywheel bolt to? (madslackin)
Since I have this pic, I will contribute it 17mm 12-pt bolts going thru ClutchMasters 7.5 lb. flywheel into the crankshaft.
Old May 20, 2003 | 05:28 PM
97hb's Avatar
Don't forget the thread lock blue
Old May 20, 2003 | 05:47 PM
JCushing's Avatar
Default Re: What does the flywheel bolt to? (PatrickGSR94)
without
with
yeah i am a pic *****...
Old May 20, 2003 | 07:10 PM
maxxdout's Avatar
Default Re: What does the flywheel bolt to? (JCushing)
the pictures everyone is showing you are great, however they seemed to have missed a few things. First off, if you have the transmission off im sure you are looking dead in the face a torque converter as well as a flex plate (that thing with the holes in it). Yeah, these need to be removed. Oh yeah, PS: the flex plate bolts look identical from the top, however are too short too get all the way through the new flywheel and subsequently will need to be replaced with flywheel bolts.
Hope this helps any. Oh yeah, follow the torque sequence. I would recomend breaking it down into 3 seperate sets. Ex: if the value given is 75ft lbs dont go directly to 75, rather do 25 first on all, then 50, and finally 75. This will ensure more even distribution and proper seating of the 2 surfaces.
Good luck
Old May 21, 2003 | 12:36 AM
Specialk's Avatar
Default Re: What does the flywheel bolt to? (maxxdout)
thanks alot guys, that CM flywheel looks nice how do u like it?
Old May 21, 2003 | 01:36 AM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">
What tool do you use to remove these bolts? They look like they have too many sides to use a normal socket wrench...
Old May 21, 2003 | 02:23 AM
JCushing's Avatar
Default Re: What does the flywheel bolt to? (ebelp)
12 point 17mm socket
Old May 21, 2003 | 02:52 AM
Mefain's Avatar
also if your takin off a flywheel by chance...your gunna need something to keep the flywheel from spinning....or else you could damage your fingers in the flywheel teeth
Old May 21, 2003 | 06:43 AM
MugenGTR's Avatar
Default Re: What does the flywheel bolt to? (Mefain)
i also believe the bolts for the flexplate says "AT" on them and the bolts for the flywheel says "MT" on them.
Old May 21, 2003 | 08:41 AM
madslackin's Avatar
Default Re: What does the flywheel bolt to? (MugenGTR)
Do people actually read posts before replying to them? Just curious.
Old May 21, 2003 | 02:14 PM
maxxdout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenGTR &raquo;</TD></TR><TR><TD CLASS="quote">i also believe the bolts for the flexplate says "AT" on them and the bolts for the flywheel says "MT" on them.</TD></TR></TABLE>
thanks for the info. Cant recall that the bolts were marked as such, but could have been. Anyone to verify?&gt;???
ken2830
Jul 25, 2006 06:01 PM
dremmel
10
May 4, 2005 12:27 AM
Muckman
Jul 13, 2004 07:31 PM
vtec69
Apr 12, 2003 10:23 AM
3rdGteg
Sep 3, 2002 09:52 PM
