OBD-2 to OBD-1 / Service connector problem
Old May 20, 2003 | 08:29 AM
Tony Starks's Avatar
Default OBD-2 to OBD-1 / Service connector problem
I recently converted to OBD-1 and I'm throwing a code. I tried to jump the service connector, but it isn't working. Since everything in the car is OBD-2 except for the ecu will the service connector trick work? I need a way to pull this code. Any suggestions? TIA
Old May 20, 2003 | 08:34 AM
tonyxcom's Avatar
Default Re: OBD-2 to OBD-1 / Service connector problem (Tony Starks)
It should work, unless there is a misswire in your conversion harness.
Old May 20, 2003 | 08:36 AM
civcexcoupeblack's Avatar
Default Re: OBD-2 to OBD-1 / Service connector problem (tonyXcom)
I need to do the same thing. 95 ls motor in 98 civic. I am using my civic Ex wiring harness, so I dont have a service connector do I? I see a brown plug that is taped up right before the firewall, but it hase like 10 row of pins? anyone?
Old May 20, 2003 | 08:39 AM
Default Re: OBD-2 to OBD-1 / Service connector problem (civcexcoupeblack)
Yes you still have a service connector. Look above where your old ecu was mounted. It will be inside of lime green rubber boot. At least its lime green in my car.
Old May 20, 2003 | 08:58 AM
tonyxcom's Avatar
Mine looks to be more of a Green Apple color.
Old May 20, 2003 | 09:01 AM
junglerunna's Avatar
Mine is blue, and it has 2 pins. Alls I did was connect the 2 pins with a saftey pin. And you CEL should blink.
Old May 20, 2003 | 09:17 AM
Default Re: OBD-2 to OBD-1 / Service connector problem (junglerunna02)
Yes it should blink, but mine isn't. I hope its not a miswire in the harness. I payed $150 for that thing.
Old May 20, 2003 | 11:03 AM
Any other ideas?
Tehknein
Jan 2, 2015 02:30 AM
agratise
May 24, 2005 06:17 AM
