Can someone explain this craziness to me????
Old May 19, 2003 | 09:22 PM
Trial User's Avatar
Default Can someone explain this craziness to me????
I was cruising down the road today and hit a crappy section of road that would be suitable for a trophy truck. Well, my intake fell of my turbo and I ran it over and that was the end of that intake, pipe, and filter. Anyways, I was running 10-11 psi before this happened. Now I am only hitting 6 psi. I put a rag and a clamp over the intake on the turbo now. It is very thin, almost see through. Why would that lower my boost? Nothing else was screwed up, just the intake. Would the intake really affect my boost?
Old May 19, 2003 | 09:38 PM
GForceInteg's Avatar
Default Re: Can someone explain this craziness to me???? (Trial User)
Could be the amount of surface area the rag is allowing. if you would do the math a intake cone/filter has a enormouse amount of surface area i would guess about 3-4 times what yiour rag is allowing.
Old May 19, 2003 | 10:00 PM
MachAF's Avatar
Default Re: Can someone explain this craziness to me???? (GForceInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GForceInteg &raquo;</TD></TR><TR><TD CLASS="quote">Could be the amount of surface area the rag is allowing. if you would do the math a intake cone/filter has a enormouse amount of surface area i would guess about 3-4 times what yiour rag is allowing.</TD></TR></TABLE>
Doesn't matter its all going through the same sized inlet.
You might have sucked something up into the turbo. Check youe wastegate, and boost gauge.
Old May 20, 2003 | 01:43 AM
ion_four's Avatar
Default Re: Can someone explain this craziness to me???? (MachAF)
Either the rag is restricting the turbo/being sucked in, or collapsing under the force of the vaccuum, or a charge pipe came loose. I would stop using the rag, I could see it going bad and being sucked in. I would just go spend $25 and get a cheapy cone filter at autozone and put it on, save your turbo.
Old May 20, 2003 | 01:50 AM
SEFIxCivic's Avatar
Default Re: Can someone explain this craziness to me???? (ion_four)
that rag is very restrictive.
Old May 20, 2003 | 02:53 AM
Pritos's Avatar
New User
Default Re: Can someone explain this craziness to me???? (SEFI8LOxCivic)
reminds me of na people putting the 'powersock' on. heheh that is, putting a sock over the stock intake arm to get that throaty sound. Too bad the sock doesn't flow too well. I think your rag is choking your flow.
Old May 20, 2003 | 03:25 AM
Trial User's Avatar
I would have never thought that rag would restrict it that much. I only put it on to get by until my new filter gets here. I hope when I put it back on everything is back to normal. Thanks for the input.
Old May 20, 2003 | 05:53 AM
Lsos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't matter its all going through the same sized inlet.</TD></TR></TABLE>
It does. The piping has its own restrictions, and on top of that is added the restriction of the filter. The more surface area you have, the less restrictive the filter.
Old May 20, 2003 | 06:13 AM
b20turboic's Avatar
a rag ???? are you nuts ... that turbo must be sucking in alot of **** .. it will tear that rag apart get rid of it atleast use a screen if you need something NO RAG
IntegraType-R
Dec 5, 2007 05:30 PM
91EF919
Oct 4, 2007 03:13 PM
integracura
Sep 25, 2005 10:17 PM
joelrugg
Feb 23, 2004 03:34 PM
BlackFrog
Oct 10, 2003 07:39 PM
