engine is louder afer installing cams.
Old May 19, 2003 | 05:52 PM
sikcrx80's Avatar
Default engine is louder afer installing cams.
well i put in cams the other day and ever since i installed them my enginesounds louder.. now i dont mean wierd noises just everyday driving noises.
now everything is done to specs.
valve train is noisey now... it kind of sounds mean in a way..
Old May 19, 2003 | 06:00 PM
dfoxengr's Avatar
Default Re: engine is louder afer installing cams. (sikcrx80)
eesh, itll always sounds different
Old May 19, 2003 | 06:04 PM
sikcrx80's Avatar
Default Re: engine is louder afer installing cams. (hybridvteceg)
yeah ok thats what i though just wanted to hear it from other people..
Old May 19, 2003 | 06:14 PM
1_bad_EF's Avatar
Yeah dude its fine .... the growl of tough springs is cool, and I know it when I heard it at first I was a little worried. But I now can tell if someone has stiffer springs and probably cams just by listening to them idle.
P
Old May 20, 2003 | 02:08 PM
sikcrx80's Avatar
Default Re: engine is louder afer installing cams. (1_bad_EF)
just hearing that makes me feel better.
Old May 20, 2003 | 03:30 PM
leadfoot78's Avatar
After installing cams u always do a valve adjustment, everyone knows that unless they are new like the people that replied before me. If the valve clearances are too big the engine will make more noise and you will loose some performance since the valves are not opening as much and as fast as they could be. If they are to tight then you will get premature cam lobe and rocker arm wear or even braking.
Old May 20, 2003 | 06:05 PM
Al Bundy's Avatar
Yea your fine. My engine is loud as hell.
Old May 20, 2003 | 06:49 PM
Blaze45's Avatar
Brrraaaap!
Default Re: engine is louder afer installing cams. (Al Bundy)
mmm some nice lumpy cams.... some day...
Blaze
Mike Lowwryyy
Jun 11, 2014 01:07 PM
worx
Apr 26, 2012 04:57 AM
jdmitr1982
Apr 19, 2006 04:24 PM
aut0tek
May 26, 2004 11:19 AM
infinkc
Jan 22, 2002 09:43 PM
