Where the hell did my oil go?
Old May 19, 2003 | 06:37 AM
Campee's Avatar
Default Where the hell did my oil go?
1998 Civic LX. I changed my oil yesterday. I drained it out, changed the filter, and filled it back up. Then, when I went to drain the pan into the oil containers... I only had half a quart of oil! I put 3.8 quarts back in. I'm nearly positive that I am not burning oil. No black smoke coming out of my exhaust. My exhaust is white very little of it. I'm not leaking oil, I park in the same place everyday and not a drop of oil underneath it. I see no evidence of oil leaking out of my motor anywhere, the underside of it is very clean. Also, my low oil indicator NEVER has come on. So, where the hell did my oil go?
Old May 19, 2003 | 07:10 AM
Pritos's Avatar
New User
Default Re: Where the hell did my oil go? (Campee)
hmmm maybe you drained the tranny instead of the oil? *shrug*
sounds like you were low in oil and simply had .5 quarts to begin with. Didn't you watch the oil come out when you drained your pan? either that or your oil container has a leak.
Old May 19, 2003 | 07:12 AM
degooser's Avatar
Default Re: Where the hell did my oil go? (Pritos)
hope u didnt check ur oil while ur car was at an angle...
Old May 19, 2003 | 07:19 AM
4DeepCivic's Avatar
Default Re: Where the hell did my oil go? (degooser)
Drive your car, turn it off and wait till it cools down. Check it on level ground.
Old May 19, 2003 | 07:23 AM
MashiM0t0's Avatar
white **** aint good
Old May 19, 2003 | 07:55 AM
Campee's Avatar
Default Re: (MashiM0t0)
I guess I meant clear. I was on level ground when I changed my oil.
Old May 19, 2003 | 07:56 AM
Campee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pritos &raquo;</TD></TR><TR><TD CLASS="quote">hmmm maybe you drained the tranny instead of the oil? *shrug*
sounds like you were low in oil and simply had .5 quarts to begin with. Didn't you watch the oil come out when you drained your pan? either that or your oil container has a leak.</TD></TR></TABLE>
Wouldn't my low oil light have been on constantly?
Old May 19, 2003 | 10:34 AM
Campee's Avatar
Bump
Old May 19, 2003 | 05:30 PM
Pritos's Avatar
New User
perhaps you were on the median of "Check oil" and not. so you never got the light.
or the sensor is bad.
*shrug* I'm at a loss, I still think u were low to start with. and half quart coming out of your container, thats unusual, maybe it was more than that and it just seemed like .5. Did you realize that you drained so little BEFORE or DURING you draining the container?
Old May 20, 2003 | 08:42 AM
Campee's Avatar
I drained it out into a pan, then I poured the pan into a one quart oil container and it was half full. It seemed that not very much was coming out. The car was on level ground. I'm really not sure, I think it might have been leaking, but I see no evidence of that. I don't think I am burning oil, I have never seen any blue smoke come out of my exhaust. It's weird. I am nearly positive that I put the same amount of oil in the first time, it's hard to mess that up heh.
Old May 20, 2003 | 08:47 AM
nerces's Avatar
are you sure you drained your engine oil and not your tranny oil? what color is it?
Old May 20, 2003 | 08:57 AM
NiiS's Avatar
Default Re: Where the hell did my oil go? (nerces)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerces &raquo;</TD></TR><TR><TD CLASS="quote">are you sure you drained your engine oil and not your tranny oil? what color is it?</TD></TR></TABLE>
I don`t think he`s that dumb...I mean c'mon, it aint brain surgery to empty the oil. BTW, it was the bolt under the oil pan right???
If I remember correctly, the trans oil plug has to be removed using an allen or a straight drive, no? I forget....
Old May 20, 2003 | 09:06 AM
nerces's Avatar
Default Re: Where the hell did my oil go? (sinister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister &raquo;</TD></TR><TR><TD CLASS="quote">
If I remember correctly, the trans oil plug has to be removed using an allen or a straight drive, no? I forget....</TD></TR></TABLE> its a allan but hey you never know, not trying to be an ***
Old May 20, 2003 | 09:22 AM
EH3_Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pritos &raquo;</TD></TR><TR><TD CLASS="quote">hmmm maybe you drained the tranny instead of the oil? *shrug* </TD></TR></TABLE>
LOL maybe u should check your tranny my friend did that to his girlfriends accord. Drained tranny fluid and added more oil to the old oil
Old May 20, 2003 | 09:24 AM
moondoggy's Avatar
Default Re: Where the hell did my oil go? (EH2_Si)
i'm pretty sure you burn a bit of oil.......i have no leaks, etc as well but i lose about 1 - 1.5 L of oil between oil change
almost all standard hondas burns some oil between oil changes
Old May 20, 2003 | 03:50 PM
ekHatchTDot's Avatar
Default Re: Where the hell did my oil go? (moondoggy)
maybe you got a broken piston ring. check if u got black smoke
Old May 20, 2003 | 05:33 PM
EH339's Avatar
Are you using dino oil or synthetic? It's odd that your oil light wasn't on before the oil change...
EG_Civic_Si
Feb 6, 2011 04:05 AM
highwhey
Nov 11, 2010 05:53 AM
EGgoJDM
Dec 1, 2009 12:05 PM
mickey513
Feb 14, 2003 08:46 PM
