staging for racing
Old May 18, 2003 | 11:56 PM
roughrydin89's Avatar
Default staging for racing
what does everybody stage at with a b16...i have a b16 with a stage 2 racing clutch, and i tried about 2600 and i just spun the tires thru first and second....about 2000?????
Old May 19, 2003 | 01:48 AM
sleeepy808's Avatar
don't have a b16, i have a 18c in a ef9, and i lauch about 7000 at the track with slicks. any lower i fall below vtec. on the street i lauch about 4000-5000. granted i spin, but any lower i will bog. iu have a 1.6 so you have less torque, which i would think you need to launch higher. but i depends on tires mostly i believe
Old May 19, 2003 | 10:17 AM
smokinvtecCRX18's Avatar
From: yea thats right i got a flowmaster and it owns you, Oklahoma, usa
Default Re: (sleeepy808)
my friend has a b18c in a 92 hatch and i have a b16a in a 90 crx and he launchs at 2k and it gives a smokey show if he doesnt feather it, he has some what better tires than stock but not by much, and i launch at like 1k cause im on stock tires and my tires just get no traction but with better tires.
all though that would be so phat to launch at 7k, what does your hatch run?
Old May 19, 2003 | 12:06 PM
crxste's Avatar
Default Re: (smokinvtecCRX18)
I launch at 4500ish on streets at the track and it still bogs a bit
Old May 19, 2003 | 03:46 PM
Sir_Phobos's Avatar
Default Re: (crxste)
i agree with crxste, sounds like your launching a bit to low, are you heating your tires?
Old May 19, 2003 | 10:27 PM
civicdragger818's Avatar
Default Re: staging for racing (roughrydin89)
I have a ls-vtec and I know that on the street if I dump at anything over 2500 I spin like a **** unless I feather it. Well they like to spin anyway going from first to second and they dont like to hook up at all. LOL. Thats on a set of 14' steelies with el-cheepo tires. AKA ROASTOMATICS.
Old May 19, 2003 | 11:35 PM
guttedEF's Avatar
I launch between 4 and 5k with my B16. Alot of it depends on the track conditiond. I've got HX wheels w/ Azenis. People think they don't wanna spin, but you need to spin. Obviously you don't wanna do a burnout. I basically try to spin just enough that it gets traction just before I'm out of first.
I stop spinning at about 7k, get my last few R's in and go on through the gears.
Just give it a try next time. Dump it at about 4k and hammer the throttle. You won't spin as much as you think you will.
Old May 20, 2003 | 12:11 AM
i know i wanna spin, but i did a smoke show for everyone...that was at 2600 about...i practiced at 2000 and it seemed to do alright, a little bit of tire spin...all i have is a set of 16" toyo proxes...
Old May 20, 2003 | 12:18 AM
guttedEF's Avatar
Default Re: (roughrydin89)
You need to ride down the track with someone who is experienced. Let them show you how they launch and you'll understand. It's hard to describe and make you a believer without actually being able to show you.
Old May 20, 2003 | 12:36 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (guttedEF)
fully built nitrous B16 CRX.. 8K RPM launch fully slicked.. shift all gears, 9500.. 12.6 1/4 miles.. 1.6 60"s.. life doesn't get any better..
Old May 20, 2003 | 07:40 AM
raene's Avatar
I launch between 3k and 3.5k on street tires, 2.2-2.3 60' time, don't hit the gas until the tires start to hook. You'll see what I mean. 14.416 @ 97.5 mph.
I borrowed some 22X15X8 slicks on the weekend and got my best results launching at 6500 rpm. 1.98 60' time, unfortunately I hit the rev limiter a few times, so it was only a 14.2 @ 95 mph.
imzjustplayin
Jul 10, 2008 06:47 PM
DBigman
Feb 17, 2007 08:29 AM
The Airman
Jun 11, 2004 04:12 PM
slowpokesi
Aug 12, 2002 03:33 PM
