B16A2 stamp on block!?
Old May 18, 2003 | 06:20 PM
DOHCRX's Avatar
Default B16A2 stamp on block!?
hey, my brother just got his b16a2 for his 95 civic, but the block only sais b16a on it?? it has a hyrdaulic slave cylnder so how can this be? he got it from hmotorsonline.com ....im a little worried about this because we looked on a 00' civic Si block and it had b16a2..whats the deal!? thanks
Old May 18, 2003 | 06:58 PM
DOHCRX's Avatar
Default Re: B16A2 stamp on block!? (DOHCRX)
did they send him the wrong motor or what do you guys think..
Old May 18, 2003 | 07:04 PM
mugensport9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCRX &raquo;</TD></TR><TR><TD CLASS="quote">did they send him the wrong motor or what do you guys think..</TD></TR></TABLE>
**** it sounds like it
Old May 18, 2003 | 07:07 PM
redzcstandardhatch's Avatar
something different
if its got a hydro tanny, dont worry about it. ive put a b16 a1 in a 99 si, and it worked fine, we just changed all the old a2 stuff over(he blew up the stock a2, nitrous+supercharger). so we threw an a1 long block in there and sold it(yes, i know its "technically" illegal, who cares, nobody checks that in the midwest. if its got the a2 stuff on it, its the same basically
Old May 18, 2003 | 07:09 PM
civickiller's Avatar
Default Re: B16A2 stamp on block!? (mugensport9)
its probably a jdm b16a2, if thats the case it wont say b16a2, it will only say b16a.
check the block, there will be engravings on it all around which show the block number, for example like on my b18a, the back of the intake mani has a pr4 on it, and the head has a pr4 on it. and the ecu is a pr4. so i say try search for that.
also u got a hydralic tranny, the 95 civics use hydralics.
what ecu did it come with ?
Old May 18, 2003 | 08:22 PM
IhateMy93BlackHatch's Avatar
It's a JDM motor, The JDM motors are stamped different than USDM motors, the first gen and second gen B16A dont have numbers after the A, just Like the USDM Gsr is stamped B18C1 but in japan it's only B18C and if it has a hydaulic slave cylinder it's a 2nd gen B16
Old May 18, 2003 | 11:21 PM
Default Re: B16A2 stamp on block!? (IhateMy93BlackHatch)
just because it has a hydro tranny on it, doesnt mean its a 2nd gen b16, u can put a hydro tranny on a 1st gen, and u wouldnt know the difference.
like i say check around the block and see the markings, it should say p30. what ecu did u get with it ?
Old May 19, 2003 | 03:08 AM
USDM 4G VTEC's Avatar
http://asia.vtec.net/topics/b16aver.html
Old May 19, 2003 | 04:21 AM
Hondasaurs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IhateMy93BlackHatch &raquo;</TD></TR><TR><TD CLASS="quote">It's a JDM motor, The JDM motors are stamped different than USDM motors, the first gen and second gen B16A dont have numbers after the A, just Like the USDM Gsr is stamped B18C1 but in japan it's only B18C and if it has a hydaulic slave cylinder it's a 2nd gen B16</TD></TR></TABLE>
Totally correct. It's JDM.
Old May 19, 2003 | 05:01 AM
zCivic's Avatar
Default Re: B16A2 stamp on block!? (B17A Hatch)
I second that....for JDM have to look at the intake manifold and the wiring harness if available. OBDI have gray square plugs while OBDO are round and off white. Just did a 2nd gen B16A so I know this one
Old May 19, 2003 | 10:33 AM
brent_G's Avatar
Default Re: B16A2 stamp on block!? (zCivic)
yeah i was the same way when i got mine 2 years ago...just look for p30 stamped on it...it shoudl be everywhere...plus look for the grey plugs on the distributor...also...there is a number on the head that tells the year...
Old May 19, 2003 | 10:36 AM
DOHCRX's Avatar
thanks alot guys..i figured they didnt send him the wrong motor..ill see what ECU it came with.
Old May 19, 2003 | 11:22 AM
andrew dc's Avatar
dont 2nd gen block numbers start with a 5.... ie the 5 million series?
Old May 19, 2003 | 11:32 AM
DJ_SaNdOz's Avatar
why don't you just look for the year stamp?
Old May 20, 2003 | 11:52 PM
Racer613's Avatar
It is unlike Steve to make a mistake like that....It is JDM b16a....and thats what it says...unless you are in CA, It shouldnt matter anyway...
Old May 21, 2003 | 01:03 AM
vulcandan's Avatar
Default Re: B16A2 stamp on block!? (Racer613)
This damn topic comes up about 30 times a week. The mods should make a "sticky" that explains it. Kind of like the forum rules thread.
thangnhocngheo
Oct 23, 2010 08:50 AM
BoostedH
Dec 9, 2008 07:06 AM
LSR-Abuser
Dec 19, 2007 02:11 PM
trhoppe
Jun 5, 2006 03:24 PM
