DIY rear camber question?
Old May 18, 2003 | 03:32 PM
lil k's Avatar
Default DIY rear camber question?
I am about to do the DIY rear camber adjustment with the longer bolts and washers but i need to know what bolts are needed, specifically threadpitch and lengh. also how many bolts need to be used i did a search and someone said one washer for every inch lowered. Is this true and if so what thickness washers should i be using. Thanks for any help.
Old May 18, 2003 | 04:41 PM
dose's Avatar
Default Re: DIY rear camber question? (lil k)
you shouldnt need any bolts,just get some washers and use one for every degree the camber is off
Old May 18, 2003 | 04:51 PM
Quad-Damag's Avatar
Default Re: DIY rear camber question? (dose)
http://home.earthlink.net/~civ....html
Old May 18, 2003 | 11:37 PM
DragonBoy's Avatar
Default Re: DIY rear camber question? (Quad-Damge)
I picked up the washers at Home Depot, I forgot the size but they're fairly large like 1 1/2" overall and it worked great. Just make sure the bolt fits through. I also made sure they were both the same thickness. Re-install the stock bolts and get an allignment. It worked great. Good Luck.
Old May 19, 2003 | 12:22 AM
EddieHatchBlack's Avatar
Default Re: DIY rear camber question? (DragonBoy)
Don't forget the Loc-Tite to make sure the bolts stay on there. 1-year and still strong for my car.
dellman177
Oct 3, 2002 06:59 PM
.brad
Sep 9, 2002 11:41 AM
Fuster_Cluck
Jul 10, 2002 10:35 AM
Lei Siew Long
Jul 8, 2002 06:11 PM
fcuked
10
May 8, 2002 09:18 PM
