type r head on a gsr block
Im planning to put an itr head on a gsr block. is there any pros and cons that anyone can help me with? is it a good swap or a bad swap? what site can I find the swap on ?
Personally, I would save the money and get your gsr head fully built from portflow. Port and polish, 3 angle valve job, full vavle train. And that would yeild more power then a type r head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audio28 »</TD></TR><TR><TD CLASS="quote">Personally, I would save the money and get your gsr head fully built from portflow. Port and polish, 3 angle valve job, full vavle train. And that would yeild more power then a type r head. </TD></TR></TABLE>
And it will be much more expensive that a ITR head.
You will lose a little bit of compression with the type r head on your gsr block. If right now you have gsr pistons in your block, then you will have below 10.0:01 compression. The type r head may flow slightly better than the gsr head, but its nothing to go crazy over.
I think a fully port/polished gsr head would be alot better than a stock type r head.
