Oil hoses and fittings, need help a.s.a.p
Old May 17, 2003 | 11:04 PM
RCautoworks's Avatar
Default Oil hoses and fittings, need help a.s.a.p
I will make it quick, so far I have this
This will go onto my block right now, I want to mention that so you know what fitting I have already, well I don't want to hang this off my block, I want to make this
So basically I need that hose, am I correct ? Now the question is, what size hose do I need and what size does it need to be at the end ? This npt and bspt really has me confused, if anyone can help me I would gladly appreciate it.
Old May 17, 2003 | 11:05 PM
I also might need one more adapter fitting to go into the block, but can anyone help me on what hose to buy. And one more thing that confuese me. Ok take a look at this pic
See where it says you need the one fitting so the stock sender will fit in the npt T fitting, I don't need that. My stock one already goes right in. But that can't be because the T fitting is npt and the stock sending unit is suppose to be BSPT. Does that make sense to anyone ?
Modified by 90blackcrx at 2:17 AM 5/18/2003
Old May 17, 2003 | 11:26 PM
sporkcrx's Avatar
Default Re: (90blackcrx)
Like I said in your previous post, the NPT fitting will work fine in the BSP hole, they're very close and similar. Just remember to use teflon on every connection. Here's a confusing rundown in order from the block: 1/8 BSP male to 1/8 NPT female adaptor in the block. 1/8 NPT male to barb connection. hose. barb connection to 1/8 NPT male. 1/8 NPT female tee. You don't need to use another adaptor on the tee, mine was fine and didn't leak oil.
ramboPandA
Mar 26, 2016 10:17 PM
Tad
Mar 13, 2004 11:32 PM
7PSiEF9ZC
Jun 11, 2003 03:55 PM
NeXtLeVeL_TyPe_R
May 12, 2002 12:07 PM
