Brake Light problem, please help
I have a problem with my brake lights, they don't seem to work, I checked the bulbs there good, I think I checked the fuse it looks clean, but the brake lights don't work, when i turn on my lights the bulb lights up, but when I apply the brakes it doesn't. Cause you know how 92-95 civic's have 2 prong brake light bulds, only one part is lighting up. Can someone help? Could it be a fuse? I may not have checked the right one, I don't have a fuse panel diagram, so if someone coudl post a pic of what fuse works what that would be great.
When you say fuse number 42, where is that unfortunatly, I don't see and numbers, and i don't have the panel with the diagram
mine went out with my instrument panel (92-95)... the parkings still worked but the brake lights went out... check the instrument panel fuse... Mine went because I pinched the ashtray light wire and it shorted out.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Does your horn work? They run off the same fuse.
can someone tell me where this fuse is located at? apparently my brake lights and horn just stop working.
</TD></TR></TABLE>can someone tell me where this fuse is located at? apparently my brake lights and horn just stop working.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G triple O.G »</TD></TR><TR><TD CLASS="quote">
can someone tell me where this fuse is located at? apparently my brake lights and horn just stop working.</TD></TR></TABLE>
Underhood fuse box.
Underhood fuse box.
b18c1vtecdc2
Sep 2, 2013 09:31 PM
Check that fuse.....
