Brake Light problem, please help
Old May 17, 2003 | 05:11 PM
Sassafrass's Avatar
Default Brake Light problem, please help
I have a problem with my brake lights, they don't seem to work, I checked the bulbs there good, I think I checked the fuse it looks clean, but the brake lights don't work, when i turn on my lights the bulb lights up, but when I apply the brakes it doesn't. Cause you know how 92-95 civic's have 2 prong brake light bulds, only one part is lighting up. Can someone help? Could it be a fuse? I may not have checked the right one, I don't have a fuse panel diagram, so if someone coudl post a pic of what fuse works what that would be great.
Old May 17, 2003 | 06:31 PM
Chiovnidca's Avatar
Default Re: Brake Light problem, please help (Sassafrass)
Does your horn work? They run off the same fuse.
Old May 17, 2003 | 09:33 PM
Sassafrass's Avatar
Default Re: Brake Light problem, please help (Chiovnidca)
Don't have a horn
Can anyone help, please
Old May 17, 2003 | 09:40 PM
95hbMatt's Avatar
Check the fuse under the hood.....It's labeled the STOP light fuse...not brake light... Check that fuse.....
Old May 17, 2003 | 10:00 PM
Sassafrass's Avatar
Default Re: Brake Light problem, please help (95hbMatt)
Aight I'll try that, but does it sound like a fuse?
Old May 18, 2003 | 06:00 AM
Sassafrass's Avatar
Come on someone gottas be able to help
Old May 18, 2003 | 06:07 AM
Pritos's Avatar
New User
sounds like a fuse problem to me.
its fuse #42, a 20amp, and wire color is Wht/Grn
Old May 18, 2003 | 06:18 AM
Sassafrass's Avatar
and all the fuses under the hood are fine
Sassafrass's Avatar
When you say fuse number 42, where is that unfortunatly, I don't see and numbers, and i don't have the panel with the diagram
Old May 18, 2003 | 06:29 AM
NonovUrbizniz's Avatar
Loved
mine went out with my instrument panel (92-95)... the parkings still worked but the brake lights went out... check the instrument panel fuse... Mine went because I pinched the ashtray light wire and it shorted out.
good luck
Old Sep 4, 2003 | 12:54 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Does your horn work? They run off the same fuse. </TD></TR></TABLE>
can someone tell me where this fuse is located at? apparently my brake lights and horn just stop working.
Old Sep 4, 2003 | 01:18 PM
Chiovnidca's Avatar
Default Re: Brake Light problem, please help (O.G triple O.G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G triple O.G &raquo;</TD></TR><TR><TD CLASS="quote">
can someone tell me where this fuse is located at? apparently my brake lights and horn just stop working.</TD></TR></TABLE>
Underhood fuse box.
b18c1vtecdc2
Sep 2, 2013 09:31 PM
ek4_b16a
Jul 2, 2009 10:20 AM
keepitngga1
Jul 18, 2008 10:26 PM
dankies
Feb 8, 2006 08:32 PM
AutoboTxEK
Mar 9, 2002 09:46 PM
