5 lug conversion
I currently have a 99 Civic Hatchback, I want to do a 5 lug conversion. Will it bolt in like stock suspension, or will I be forced to some fabricating. Who sells the 5 Lug conversion?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-DA »</TD></TR><TR><TD CLASS="quote">not searching is ghey</TD></TR></TABLE>
yes it is,
but everything bolts up, go to any jdm sites like passwordjdm, etc.
yes it is,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex jabbar »</TD></TR><TR><TD CLASS="quote">I heard you cannot really cannot launch with the b18c, without this swap because you need the 36mm Axles that come on the 98+ ITR</TD></TR></TABLE>
JDM ITR used the 36mm. usdm is 35mm. it really doesn matter its all the same. and everything bolts up. very easy to do.
check this out. https://honda-tech.com/zerothread?id=505126
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanHatch »</TD></TR><TR><TD CLASS="quote">
check this out. https://honda-tech.com/zerothread?id=505126 </TD></TR></TABLE>
thought u knew better, comin from a guy that has the same car as i do, hehe
wasup man
wasup man
lol shiet mybad! too damn early for me!
wut i ment when i said the same, is that it doenst really matter if you go with the jdm suspension and use the 36mm axle or the usdm 5 lug suspenion 32mm axle.
guywitaDA
Jul 13, 2005 06:29 PM
