Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR
Old May 16, 2003 | 06:55 PM
canuck-mx6's Avatar
Default Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR
The JDM ITR SRS momo wheel is a direct plug in for 96-01 cars, but on OBD1 cars, the airbag connector is different.
Let me say that after asking a million questions which no one could answer, I realized that I could swap the connector from my old airbag to the JDM airbag by unlocking the pins, similar to what I had done to install two new pins for my power folding mirrors. The only thing is that the old connecter has three pins, the JDM has two. I realized that the centre pin does nothing as the USDM airbag has only two wires, a red and a white
Dilema number two, the JDM airbag has two red wires, which is positive and which is negative. Gotta admit for that one, the horseshoe was stuck up my a$$. I took my chance, installed the JDM wheel, plugged in the airbag and reconnected the battery. Sitting in the passenger seat, I reached over and turned the ignition..........
Nothing blew
I looked at the guauges, and after six seconds, the SRS light went off indicating that the system was functioning normally.........whew. Only one small problem, my horn does not work, but I will trouble shoot that tomorrow.
Old May 16, 2003 | 07:15 PM
Calavera's Avatar
Default Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (canuck-mx6)
Thats a problem I ran into when I swapped a '00 USDM steering wheel into my '95 GSR (OBD1) the SRS connector was different.
What do you mean by "unlocking the pins?" Are you saying you pulled the wires going into the connector out and put it back into the correct connector? Got some visual aids?
Old May 16, 2003 | 07:33 PM
canuck-mx6's Avatar
Default Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (Calavera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">Thats a problem I ran into when I swapped a '00 USDM steering wheel into my '95 GSR (OBD1) the SRS connector was different.
What do you mean by "unlocking the pins?" Are you saying you pulled the wires going into the connector out and put it back into the correct connector? Got some visual aids? </TD></TR></TABLE>
That is exactly what I am saying, you can move the pins from one connector to another by unlocking them with a paperclip. For an example, see step 4 at http://students.washington.edu...s.htm
You can do the same thing with the airbag connector pins
Old May 16, 2003 | 07:42 PM
Calavera's Avatar
so basically, all I really need is the correct connector. right?
Old May 16, 2003 | 07:49 PM
canuck-mx6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">so basically, all I really need is the correct connector. right? </TD></TR></TABLE>
Yes, all you need is the right connector. I moved the one off my USDM airbag to my JDM air bag. You can move the one from your OBD1 airbag to your OBD2 bag
Old May 17, 2003 | 12:52 AM
tC_Dragon's Avatar
wow good job on that steering wheel bro... i always wanted that steering wheel too and when i saw ur post i think last week or earlier this week about it, i was really dissappointed to learn about that whole 94-95 tegs and their incompatability.
thanks for pavin the way! And good luck with teh horn. oh and u know i'll be watchin for a post about that when u fix it. hehee...
Old May 17, 2003 | 04:12 AM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (pdcdragon)
thats kewl, does it look nice ?
Old May 17, 2003 | 05:22 AM
canuck-mx6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdcdragon &raquo;</TD></TR><TR><TD CLASS="quote">wow good job on that steering wheel bro... i always wanted that steering wheel too and when i saw ur post i think last week or earlier this week about it, i was really dissappointed to learn about that whole 94-95 tegs and their incompatability.
thanks for pavin the way! And good luck with teh horn. oh and u know i'll be watchin for a post about that when u fix it. hehee... </TD></TR></TABLE>
I figured out what is wrong with the horn, the horn shares a wire with the cruise control. Since I took out the cruise control switch, there is an open circuit. In cars with no cruise control, there is a jumper that is put on the cruise control harness to close the circuit.
Yes, the wheel does look good, is leather wrapped, still has airbag protection and is nice and small compared to the USDM wheel
Old May 17, 2003 | 10:53 AM
tC_Dragon's Avatar
so did you put in the wire/jumper to close the circuit and make ur horn work??
and again..
Old May 17, 2003 | 02:35 PM
Calavera's Avatar
My steering wheel's honk doesn't work either, but I found out I dont even have a honk. Would it be a good idea to connect an airhorn to it? I never heard these, but seems loud and more "manly" than the stock "beep beep" road runner sound.
Old May 17, 2003 | 05:00 PM
HondaIntegraLS's Avatar
I almost pissed myself when reading "Sitting in the passenger seat, I reached over and turned the ignition..........
Nothing blew "
Good Job
Old May 17, 2003 | 07:40 PM
canuck-mx6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdcdragon &raquo;</TD></TR><TR><TD CLASS="quote">so did you put in the wire/jumper to close the circuit and make ur horn work??
and again.. </TD></TR></TABLE>
Yes, that is exactly what I did. Thank God for the helms, without it I would be lost. I looked at the circuit diagram for the horn, and realized that it shared a wire with the cruise control.
Old May 18, 2003 | 10:55 PM
tC_Dragon's Avatar
bump for all those who haven't seen this yet... Time for me to bookmark this...
Old May 19, 2003 | 06:34 AM
JDMTEG2003's Avatar
very informative post, i've been looking into a jdm itr srs momo wheel for my 97 teg also...i've been doin research on the board and found that the turn signals malfunction a bit??? being that they do not automatically turn off when making left/right turns??? somebody correct me if i'm wrong here... canuck mx6, does this happen to u after the install? and btw, i think u've got one of the sweetest teg's i've ever seen
Old May 19, 2003 | 06:52 AM
Danger's Avatar
Default Re: (Mike C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">I almost pissed myself when reading "Sitting in the passenger seat, I reached over and turned the ignition..........
Nothing blew "
Good Job</TD></TR></TABLE>
hahahah i was laughin so hard when i read that in the origial post . good idea though
Old May 19, 2003 | 06:54 AM
SIK IN DA HED's Avatar
New User
Default Re: (JonnyDanger)
sweet. post up some pics or somethin.
Old May 19, 2003 | 09:07 AM
tC_Dragon's Avatar
Default s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIK IN DA HED &raquo;</TD></TR><TR><TD CLASS="quote">sweet. post up some pics or somethin.</TD></TR></TABLE>
i second this..
Old May 19, 2003 | 02:31 PM
canuck-mx6's Avatar
Default Re:
Wheel is in this
Old May 19, 2003 | 05:10 PM
Comp97GSR's Avatar
Default Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (JDMTEG2003)
CONGRADULATIONS!!!!! I did this swap 3 months ago on my 97 GSR. I guess we all learn the little differences between model years. As far as the question about the turn signals, there is a small issue but anybody with mechanical ability can fix/modify it to work. I will attempt to explain. The SRS reel has 2 tabs in the back of it that fit in the signal cancel sleeve verticaly, the hub of the SRS wheel has notches in it to fit in the signal canceler sleeve horizontaly. I removed the 2 tabs in the back of the SRS reel so only the steeringwheel cancels the signals. No problems. I can post pics of the mod to the SRS reel if you would like.
Edit: added the pic.
Modified by Comp97GSR at 8:21 PM 5/19/2003
Old May 19, 2003 | 05:11 PM
97CivicLS's Avatar
sweet ride man, how much was the wheel and where did you get it?
Old May 19, 2003 | 05:26 PM
tC_Dragon's Avatar
Default Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (Comp97GSR)
i'm sure people would appreciate pics of it, if u have them around. hehe... then i'd only have to bookmark this one post for my future needs hehehe... dat is if i ever have money for that thing. hahaha..
EDIT: thanks
Old May 19, 2003 | 05:32 PM
Comp97GSR's Avatar
And because the rods that are on the SRS reel fit into the USDM wheel at an angle, and they will have to go into he JDM wheel level (horizontaly) that the UP on the reel will be slightly to the right and will maintain 2 1/2 rotations in both directions so there will be no problem with the reel snapping. (The steering column only has 1 1/2 rotations to each side of center.) That is th reason peeps have problems with the signals not canceling, just remove as in the pic above and the world isa much safer place.
Old May 19, 2003 | 07:00 PM
TerribleOne's Avatar
thats a CLEAN car....wow someday I hope that my car is that clean
Old May 19, 2003 | 08:33 PM
sergio's Avatar
Default Re: Re: (canuck-mx6)
That is such a sweet wheel! Maybe someday I will have it on mine, it will match great when I paint my car Milano Red soon. Not only that, but your car is beyond clean. Awesome!
Those CP-035's are on my list as well!
Old Jan 9, 2004 | 09:34 PM
Kagy's Avatar
New User
A couple of questions:
Does removing the tabs in the srs reel cause any problems when re-attaching the USDM wheel?
Is there anyone in the DC Metro area that I can pay to do the install properly and safely?
thanks, Kevin
