Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR
#26
Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (Kagy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kagy »</TD></TR><TR><TD CLASS="quote">A couple of questions:
Does removing the tabs in the srs reel cause any problems when re-attaching the USDM wheel?
Is there anyone in the DC Metro area that I can pay to do the install properly and safely?
thanks, Kevin
Not sure, I have not reattached the USDM wheel.
thanks, Kevin
#27
Re: (HondaIntegraLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaIntegraLS »</TD></TR><TR><TD CLASS="quote">I almost pissed myself when reading "Sitting in the passenger seat, I reached over and turned the ignition..........
Nothing blew "
Good Job</TD></TR></TABLE>
HAHA i was laughing at that too...i imagined the airbag just going KABOOM
Nothing blew "
#29
Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (dc-gurl)
Modified by canuck-mx6 at 2:03 PM 3/21/2004
#36
Re: (au-gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC »</TD></TR><TR><TD CLASS="quote">sweet cockpit dude </TD></TR></TABLE>
for sure, that is such a clean interior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA »</TD></TR><TR><TD CLASS="quote">that wheel cost so much that i didnt even connect the srs.... **** blowing the bag up in a 400 wheel</TD></TR></TABLE>
haha, id be the same way
#37
quick update, looked into the resistance factor on the srs plug for any 94+01 drivers side airbag. any 2 ohm resistor plugged into the socket will worka nd turn off the srs light. that way your passenger will have the luxury of getting silk screen and powder burn when you get into an accident.
but here's my question what is everyone doing with the cruise control featurs. where are you moutning them?
#39
1 Post
Re: (DRAG lll INTEGRA)
kinda shameless to ask but whats worth more, a 400$ wheel or your life?
#40
Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (canuck-mx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 »</TD></TR><TR><TD CLASS="quote">
Modified by canuck-mx6 at 2:03 PM 3/21/2004</TD></TR></TABLE>
is free revving the car while sitting still to 8G really THAT good for the motor ?!
#41
Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (dubbedtodea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubbedtodeath »</TD></TR><TR><TD CLASS="quote">
is free revving the car while sitting still to 8G really THAT good for the motor ?! </TD></TR></TABLE>
Why not, its easier on the motor if there is no load on it
#43
about the horn, if my cruise control is still hooked up, then my horn will work when I put the JDM wheel in right? or am i reading something wrong and it wont work--Rich
#44
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 »</TD></TR><TR><TD CLASS="quote">Sitting in the passenger seat, I reached over and turned the ignition..........
Nothing blew </TD></TR></TABLE>
how did you push the clutch in from the passenger side?
#46
Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (speedracex)
With any steering wheel swap, if it is done right you should always have your horn. The cruise control on this wheel is something else. Mine is still functional (part time anyway) but there is no GOOD way to mount the buttons.
Diameter ? I can't remember, it is larger than the non-srs wheel but smaller than stock.
#47
Re: Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR (Comp97GSR)
bump*****
#48
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracex »</TD></TR><TR><TD CLASS="quote">about the horn, if my cruise control is still hooked up, then my horn will work when I put the JDM wheel in right? or am i reading something wrong and it wont work--Rich</TD></TR></TABLE>
you can turn the ignition on without turning the car on. The SRS check is done when the ignition is on.
#49
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 »</TD></TR><TR><TD CLASS="quote">you can turn the ignition on without turning the car on. The SRS check is done when the ignition is on.</TD></TR></TABLE>
My bad, I confused "ignition on" with "car on"
#50
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracex »</TD></TR><TR><TD CLASS="quote">bump*****
Your cruise control has nothing to do with your horn. IF you are talking about the JDM SRS wheel, if you haven't destroyed the cable reel, the horn will work same as stock.....just plug the connector in. Like I said the cruise control will not mount on the JDM wheel. There is a velcro panel on the side of the JDM wheel. I have my cruise connector conveniently located behind it and if I am on a long drive I plug it in and velcro my cruise buttons to the side of the steering wheel. If I wanted to be creative I could permanently mount the buttons but in doing so I would decrease the value of the wheel.
Furthermore, regardless aas to whether or not you have your cruise hooked up, your horn should still work.
