Tachometer wire on 91 civic hatchback
Old May 16, 2003 | 03:32 PM
Datdeviljuice's Avatar
Default Tachometer wire on 91 civic hatchback
I'm about to be given a 1991 honda hatchback. I was wondering which and where is the wire that i would need to hook up an autometer 5 inch monster tach with shift light. If anyone knows the wire color.. inform me of anything..
Old May 16, 2003 | 06:02 PM
JCRacer18's Avatar
the blue wire coming out of your distributor should be the answer as that is the wire to the coil
Old May 16, 2003 | 06:10 PM
Hondasaurs's Avatar
Default Re: Tachometer wire on 91 civic hatchback (Datdeviljuice)
Its on the 2 plug harness on the dizzy next to the fat black/yellow wire.
Old May 16, 2003 | 07:17 PM
OutLuDeD's Avatar
Default Re: Tachometer wire on 91 civic hatchback (B17A Hatch)
OR....you can take off your dashboard hood. under it youll see 2 big plugs. in the left plug youll see a blue wire. thats your coil.
Old May 16, 2003 | 11:58 PM
FR-MOB: ThE bEe GuY's Avatar
Also, after you install it and go into the higher RPMs, dont be surprised if your stock tach is a little off from your Autometer tach. Our civics/CRX stock tachs get more and more innaccurate the higher the RPM's go. With mine, when my Autometer tach is at 6500, my stock one is at something around 7100... So look at the autometer one. Up to about 3-4000, the stock tach is fine but after that, thats when it gets screwy.
Old May 17, 2003 | 12:09 AM
xsellxoutx's Avatar
i suggest getting a proform shiftlight instead of the tack w/light I trader my autometer5"w/light for a proform light a love it.
Old May 17, 2003 | 05:23 AM
The car didn't come with a tach anyways, and for functionality purposes.. i want one with a shift light!
Old May 17, 2003 | 06:57 AM
Hondasaurs's Avatar
Default Re: (Datdeviljuice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Datdeviljuice &raquo;</TD></TR><TR><TD CLASS="quote">The car didn't come with a tach anyways, and for functionality purposes.. i want one with a shift light! </TD></TR></TABLE>
You can swap clusters with an Si model of the same year. If you have an 88-89 then use a 88-89 Si cluster. If you have a 90-91 you need a 90-91 Si cluster. Plug and play.
Old May 20, 2003 | 05:26 AM
naw i don't wanna swap clusters, i'll just go with aftermarket guage, but thanx all!
Old May 20, 2003 | 07:49 AM
EFsleeper's Avatar
you can also catch the blue wire in the passenger side plugs of the harness if you dont want to run a wire over your engine and make it look messy.
Old Jan 28, 2014 | 04:18 PM
GeArHead1973's Avatar
I haven't had any luck getting my Sunpro Mini Tach to function at all except with the lights. Red wire is attached to a spot that comes on with the ignition, white wire is attached to the headlight switch, black is to a good ground or else the lights wouldn't come on, but I am having trouble finding where to hook the green wire. It's a 1990 Civic DX hatchback, 4 speed manual tranny with no factory tachometer.
Old Jan 28, 2014 | 04:19 PM
Does anyone have any suggestions? I have tried several other locations that people have suggested with no luck.
Old Jan 28, 2014 | 04:31 PM
ej1995's Avatar
Blue wire at distributor...its very simple.
Old Jan 29, 2014 | 06:41 PM
Riceburner247's Avatar
You could also just install an Si cluster that already has a tach in it.
Old Feb 24, 2014 | 08:01 PM
famdakam's Avatar
Icon2 Re: Tachometer wire on 91 civic hatchback
Did you figure out how to wire the tachometer if so let me know
Old Feb 25, 2014 | 03:01 AM
Freemananana's Avatar
The blue wire on the small plug on the distributor. That or under the dash on the back of the cluster.
Old Feb 25, 2014 | 06:29 AM
4drEF's Avatar
Keyboard Humorist
2003 post.
These people had it right 10+ years ago.
Why would anyone suggest hook up a dash mounted tach by running a wire all the way out into the engine bay to the distributor?
Old Feb 25, 2014 | 08:39 AM
That's what the instructions on aftermarket tachs suggest. Not saying it's the best or right way to do it, but some of the instructions suggest wiring it to the distributor.
Old Sep 12, 2023 | 09:27 PM
RobCo's Avatar
I know the thread is old, but if it helps the clock wiring is almost tailer made for a tach. It has a full time power (wh/blue), ignition power (Yellow), a headlight activated power (red - if your tach has a dimmer) and a ground (Black). Everything you need except the tach wire (blue in left most connector on cluster). Better yet it will pull through to the cluster compartment by removing the grommet in the air compartment. I shoved a foam ear plug in the grommet hole and wrapped with electrical tape. Works a treat.
I personally depinned the clock connector and put it in the holder for a blank I have installed in case I ever change my mind. Hope this helps as much as the OG posts helped me.
esean93
Aug 23, 2008 10:33 AM
teddy_dc2
Mar 15, 2007 07:02 PM
1sikhatch
11
Mar 14, 2006 09:19 PM
YellowCRXSi
Jul 12, 2004 09:55 PM
91sifreak
Feb 26, 2002 01:55 PM
