I can't believe this happened. I need new motor mounts.
Ok, I was driving threw town, not driving hard or nothing, took off from a stop sign, and the car started vibrating really bad, thought I got a flat tire. Looked around the car, saw nothing, untill i looked under the car. I saw the lowor motor mount broke and hanging like 6 inches low, opened the hood, and saw the upper motor mount broke also. So the motor wat just agaist the fender hanging there. How does the mounts just break like that? SO now I need new mounts, lower and upper drivers side. And while im doing this, I think I should just get all new mounts and get stiffer mounts, I have enough money to do it, so if anyone has a nice set of mounts for me, let me know. Not too expensive though. But I would need all 5 mounts, rear, both upper mounts, and both lower mounts. Don't need the brackets for the lowers, just the rubber parts. Please let me know ASAP. I need to fix my car as soon as I can. Ill rip the motor out and start to fix the broken stuff, then put new mounts on the car. Hit me up with any one who can hook me up with mounts.
just looking for gsr motor mounts. Looking for something stiffer than stock so this problem doesn't happen again.
dam Matt u sure have a lot of bad luck with your car. hope to be sending u the trannie asap! btw i have the mounts!
yeah brian- seems everything is going wrong with my car. I think I found out that my upper mount has been bad for a while, and the lower mount finally gave out, I also think thats why it wouldn't go in gear half the time, if the motor is slanted enough, the shifter bar and stabilizer bar will screw up the smooth shifting im supossed to get.
brian, do you have OEM mounts? or stiffer mounts? Let me know. I will need new lower torqe mounts, and upper mounts, and rear, unless you have OEM mounts, then I just need drivers side stuff. but did you get my check yet? Let me know.
But im still open to see if anyone has a nice set of stiff mounts they don't need.
I have two of the type R mounts you need/want...let me know- maryonelia@hotmail.com
OK, I found out that my drivers side upper mount just broke the bolts, and then my lower mount broke. So all I need is the lower drivers side torqe mount. And then Im going to buy new insters. What have everyone found to be a good brand of inserts?? let me know. Let me know who has the mount I need, and inserts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c-rDC2 »</TD></TR><TR><TD CLASS="quote">energy or prothane inserts should do just fine!</TD></TR></TABLE>
yeah what he said. Stock mounts + Energy or prothane motor mount inserts
where can I get these inserts? And about how much are they??
THe main thing is that I still need a lower drivers side torqe mount!!!
still need lower drivers side mount, and I have a question. WHen I buy teh ES mount inserts, it is for all 5 mounts? or just 3? Im wondering becasue all my mounts aren't the same, like my torqe mounts and my rear are stock stock mounts. And my upper mounts are the gsr. So how would I go about getting inserts? Do I buy 92 honda civic inserts or 99 gsr inserts???
bump*** I still need the lower drivers side mount. most 92-99 civics are the same I think, and some gsr's. But I got myself some inserts, but I still need the mount.
for an update, I need the upper divers motor mount from a gsr. My motor is a 99, so I think any 95-99 gsr's are the same. And 96-99 civic SI I think have the same mount. Let me know if anyone has one for me.
Bbasso
Mar 4, 2005 05:48 PM
