Anyone tried UberTeg's chip+AFC over 11psi??
Old May 16, 2003 | 01:40 PM
shermanyang's Avatar
Default Anyone tried UberTeg's chip+AFC over 11psi??
I'm just wondering because I may want to do this once I get my F#CKED up turbo back from it's rebuild. I'm gonna get it dyno tuned so I"m not worried about it blowing or anything. Just wondering if it's even possible since UberTeg's chip is made to work with 450's from the start.
Old May 16, 2003 | 01:50 PM
omahaturbocivic's Avatar
Default Re: Anyone tried UberTeg's chip+AFC over 11psi?? (shermanyang)
The problem with anything over 10psi is the stock map sensor cannot read over 10 psi. If you go over 10psi the ecu will not be able to add anymore fuel because the map sensor will stop reading boost at 10 psi and you will start to run lean. I have not heard that ubertegs software is calibrated to work with a 2 or 3bar map sensor yet. Maybe if someone had a 2 or 3 bar map sensor and ubertegs software they could try tuning it with one and see how it work out.
Old May 16, 2003 | 01:56 PM
Default Re: Anyone tried UberTeg's chip+AFC over 11psi?? (omahaturbocivic)
true...I know I would need a 3 bar MAP, but I was wondering if with just a 3BM sensor, could i go the easy route and just tune w/the AFC instead of reprogramming the ecu? I'm getting UberTeg's software pretty soon too so i'm not too worried, just want to know if it could be done.
Old May 16, 2003 | 02:05 PM
Sonny's Avatar
Just wait for the 3bar version of his chip. Relying on the AFC to correct for the 3 bar sensor AND to tune fuel doesn't sound like a recipe for success.
Sonny
Old May 16, 2003 | 02:52 PM
swrdply400mrelay's Avatar
Default Re: Anyone tried UberTeg's chip+AFC over 11psi?? (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Sonny</TD></TR></TABLE>
How is he going to announce it? He got banned....
projectjazzmine
Engine Management and Tuning
Jun 10, 2008 09:38 AM
EX-T
Feb 10, 2007 11:10 PM
rdssk8rcs1
Oct 10, 2006 06:43 AM
CiViC SiR
Jul 7, 2003 02:22 PM
fast[R]
Jul 18, 2002 03:00 PM
