idle problem after swap.......
Old May 15, 2003 | 11:47 PM
intezn's Avatar
Default idle problem after swap.......
ok b18b into eg
i also did a brake swap too front and rear
so after all that, what is the idle i should set to?
and right now, i think is at 1000.
the problem is when the car is at a stop, when i step on the brake, the idle jumps up and down......
why is that?
Old May 16, 2003 | 07:31 AM
intezn's Avatar
Default Re: idle problem after swap....... (intezn)
Old May 16, 2003 | 07:51 AM
esoterEK..'s Avatar
Got this from TOM:
this could be your problem.
Here's what you do:
Pull off the the fast idle valve from the bottom of your TB. It'll be held in by maybe 4 10mm nuts. It'll also have a coolant line on it or two, so disconnect those too.
Then take a phillips head screwdriver and take off the two screws on the end cap and look inside.
Inside there will be a big plastic plate that should be screwed into the FIV itself. Usually this spring-loaded plate comes unscrewed and messes up your idle. Take some RVT sealant (preferably Hondabond) and put it on the edge of the plastic disc. Screw it back in about halfway and reinstall the FIV.
Adjust the idle via the throttle mixture screw and that should pix the problem.
If the spring inside of the FIV is broken then buy a new FIV for like $40.00 or something like that from Honda.
Old May 16, 2003 | 07:55 AM
al3e's Avatar
Default Re: idle problem after swap....... (EGkwazhimoto)
yeah...what he said....
Old May 17, 2003 | 11:46 AM
intezn's Avatar
thanks, i will look into that.......
i was thinking of putting my stock si one back on, but if that works, it will be cool, save me whole lot of trouble.....
Old May 31, 2003 | 08:27 AM
BEV@GSCMotorsports's Avatar
if that doesn't work check to make sure the TPS (throttle position sensor) is in the propper adjustment.
Ohmega
19
Mar 9, 2016 04:48 AM
followthadollar
Apr 21, 2010 02:46 PM
LoSt is BlaCk
Mar 26, 2004 05:07 AM
killa_lude
Aug 16, 2003 08:33 AM
chirp2hrd
Oct 13, 2002 01:36 AM
