idle problem after swap.......
ok b18b into eg
i also did a brake swap too front and rear
so after all that, what is the idle i should set to?
and right now, i think is at 1000.
the problem is when the car is at a stop, when i step on the brake, the idle jumps up and down......
why is that?
why is that?
Re: idle problem after swap....... (intezn)
Got this from TOM:
this could be your problem.
Here's what you do:
Pull off the the fast idle valve from the bottom of your TB. It'll be held in by maybe 4 10mm nuts. It'll also have a coolant line on it or two, so disconnect those too.
Then take a phillips head screwdriver and take off the two screws on the end cap and look inside.
Inside there will be a big plastic plate that should be screwed into the FIV itself. Usually this spring-loaded plate comes unscrewed and messes up your idle. Take some RVT sealant (preferably Hondabond) and put it on the edge of the plastic disc. Screw it back in about halfway and reinstall the FIV.
Adjust the idle via the throttle mixture screw and that should pix the problem.
If the spring inside of the FIV is broken then buy a new FIV for like $40.00 or something like that from Honda.
Here's what you do:
Re: idle problem after swap....... (EGkwazhimoto)
thanks, i will look into that.......
i was thinking of putting my stock si one back on, but if that works, it will be cool, save me whole lot of trouble.....
Ohmega
19
03-09-2016 04:48 AM
