Turbo n00b installation mistake #1 :(
Ok, get this - I just got my Greddy Kit on this eveing (Loved it for the 5 minutes I got to drive it
) but none the less somehow we fucked up the oil feed line on the turbo's end. Its leaking like a drippy faucet.
Can someone please explain to me the best way to seat the nipple/tube on the inside of the line's fitting? And can this tube/nipple be easily bent? If so I think thats what happened to mine. Thanks in advance.
Btw, b00st OWNS - even though its only 5.5 lbs, its exactly what I was hoping for.
Modified by Cody at 7:30 AM 5/16/2003
Can someone please explain to me the best way to seat the nipple/tube on the inside of the line's fitting? And can this tube/nipple be easily bent? If so I think thats what happened to mine. Thanks in advance. Btw, b00st OWNS - even though its only 5.5 lbs, its exactly what I was hoping for.
I'm talking about the threaded nut on the line that you run onto the banjo fitting. Another question how expensive are the steel braded lines mentioned?
i thought you were getting rid of the turbo. glad to see you decided to go on with it. i just finished putting mine on as well and going to get tuned at balanced thursday am. when where are you going to tune? sorry i can't help on the line...mine is pure ghetto.
:Bumpizzle: I'm not exactly when I'm plannin' on tuning it, i guess whenever i round up the cash.
Modified by Cody at 5:51 PM 5/16/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cody »</TD></TR><TR><TD CLASS="quote">even though its only 5.5 lbs, its exactly what I was hoping for.
That won't last long. Soon you'll be craving more boost and emptying your wallet to get it! Ramen Noodles will own you!!!!
</TD></TR></TABLE>That won't last long. Soon you'll be craving more boost and emptying your wallet to get it! Ramen Noodles will own you!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony Starks »</TD></TR><TR><TD CLASS="quote">
damn...i've never heard more truthful words before!
</TD></TR></TABLE>damn...i've never heard more truthful words before!
lol ramen noodles own me and i dont even have a turbo
</TD></TR></TABLE>lol ramen noodles own me and i dont even have a turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">Ramon noodles are the bomb *** ****.</TD></TR></TABLE> Ramen noodles are too expensive for me....I live off of Spam and Kool Aid
Yuuummm, I can already taste the SMG
. I'll keep that in mind lol, next thing ya know I'm dealin' rock to facilitate my b00st fix.
But does anyone know about any complications with that oil feed line, is the tube inside the end-fitting easily fubared?
</TD></TR></TABLE>Yuuummm, I can already taste the SMG
Ok what exactly was your problem man. U were leaking OIL from your BLOCK fitting?
Are u not using Steel Braided hoses or what
he is 110% right on this comment! its neverending! ha ha
</TD></TR></TABLE>he is 110% right on this comment! its neverending! ha ha
is the oil leaking from the block? cause if it is, (pray to god it isnt) then that means u tightened the fitting into the block too much and u cracked it. happened to me and left me boostless.
but if its just the stainless steel lines then u can just replace it. what i would do to make sure is to take off the oil feed line fitting off the block completely and double check the block is alright. make sure there are not hairline cracks or chips. ok, good luck. hope everything goes well
EDIT: ok, i reread your first post like 3 times and realized its not the block that u are leaking from, but the turbo itself. sorry
Sorry for the mixup, but I meant the actual fitting at the end of the steel braded line (turbo's end of the line connected to banjo fitting). Thanks for all the input and help guys - with all your help, luck, and dropping the entire manifold and snail (yet again lol) I was able to cure the leak at the end of the line.
. And now I've seen the light - where can I invest in a Maruchan franchise?
Thanks again guys.
Thanks again guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG4ACCORD »</TD></TR><TR><TD CLASS="quote">
he is 110% right on this comment! its neverending! ha ha </TD></TR></TABLE>
soo not true! keep your stock tires and you'll see that more boost is useless.
no way.... all the sweet noises you can make next to people with their windows down is good enough
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR »</TD></TR><TR><TD CLASS="quote">
thats why my slicks own me!
Thats what I said. When i got into the turbo game, I just wanted to be able to climb hills easier. A little over a year later, I ended up with a motor built from top to bottom.
</TD></TR></TABLE>Thats what I said. When i got into the turbo game, I just wanted to be able to climb hills easier. A little over a year later, I ended up with a motor built from top to bottom.
Sup cody, this is Vince from SI Atlanta or whatever they call it now
I just got my greddy kit on this past saturday. I didn't seem to have a problem when i installed that oil feed line... However, i used Hondabond for almost every fitting on the damn kit.... lemme know how it works out.
The feed line isn't bad at all, its the return that's crap...but that's how they keep the price down as an entry level turbo.
lol...oh so true!
</TD></TR></TABLE>lol...oh so true!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">
Thats what I said. When i got into the turbo game, I just wanted to be able to climb hills easier. A little over a year later, I ended up with a motor built from top to bottom. </TD></TR></TABLE>
Oh crap...so in a year i can expect to have a built motor then. Better find the aussie equivalent of these Ramon noodles
teg racer 877
Jun 28, 2006 08:09 PM
