auto to manual conversion help
ive got a '91 civic hatch dx auto, want to make it 5 speed.I know i need a 5 speed tranny, shift linkage,clutch pedal assembly,clutch cable,a 5 speed pas. side bracket needs to be welded in place of the auto,clutch,flywheel,5 spd. flywheel bolts, 5 speed tranny mounts.I need to know what else, can i use the same ecu, and will i have to do any wiring? thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fearless_dsm »</TD></TR><TR><TD CLASS="quote">ive got a '91 civic hatch dx auto, want to make it 5 speed.I know i need a 5 speed tranny, shift linkage,clutch pedal assembly,clutch cable,a 5 speed pas. side bracket needs to be welded in place of the auto,clutch,flywheel,5 spd. flywheel bolts, 5 speed tranny mounts.I need to know what else, can i use the same ecu, and will i have to do any wiring? thanx
OK first you dont have to weld any mounts into different places just get the manual mounts and they will bolt right in and line up with the tranny. You will need a manual ECU. As for wiring your going to have to run the wires from the auto shifter out to the tranny for the reverse lights and your going to have to wires the park wires together so your car thinks its in park and will start or you can take those wires and run them to the nuetral safety switch and have it that was as well. That should be pretty much it with wiring I believe?? I am doing the same thing but I am also putting the Si motor into my car so I just swapped out all of the harnesses so I didnt have to mess with rewring at all.
If you have any other questions do a search cause this has been covered quite a few times.
</TD></TR></TABLE>OK first you dont have to weld any mounts into different places just get the manual mounts and they will bolt right in and line up with the tranny. You will need a manual ECU. As for wiring your going to have to run the wires from the auto shifter out to the tranny for the reverse lights and your going to have to wires the park wires together so your car thinks its in park and will start or you can take those wires and run them to the nuetral safety switch and have it that was as well. That should be pretty much it with wiring I believe?? I am doing the same thing but I am also putting the Si motor into my car so I just swapped out all of the harnesses so I didnt have to mess with rewring at all.
c1civic
10
Apr 6, 2004 05:06 PM
4door93civic
Jan 2, 2004 02:46 PM
