How to bleed the radiator fluid
Old May 15, 2003 | 08:01 PM
wantmorepower's Avatar
New User
Default How to bleed the radiator fluid
I am getting a new radiator and wanted to know the proper procedure of bleeding the coolant system. thanks
Old May 15, 2003 | 08:06 PM
.RJ's Avatar
.RJ
Default Re: How to bleed the radiator fluid (wantmorepower)
Fill at radiator cap, open bleed screw at the water neck - leave radiator cap off. You'll see the coolant bubbling out (catch it with a towell/rag), when it stops bubbling out (just comes out steady) then put the cap on and run the engine till its hot (fan comes on) with the header **** set all the way hot, check to see if you need to add coolant.
Old May 16, 2003 | 05:36 AM
benmasters's Avatar
Default Re: How to bleed the radiator fluid (.RJ)
I did mine a couple of months ago - I found all the info on here and collated into a document :-
http://www.munc.co.uk/bentemp/coolant%20change.doc
let me know when you have got it as this isnt my webspace i have uploaded it to.
Ben.
Old Feb 21, 2004 | 12:14 AM
B16CRXT's Avatar
I got a PR3 B16 and I cant seem to find my bleed screw.. any pointers?
david90
Jun 10, 2021 07:42 PM
wld2rde
Feb 10, 2005 05:54 AM
JDM00SI
Jan 26, 2005 01:21 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
