Thinking of rebuilding my engine myself. Input.
Old May 15, 2003 | 05:02 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Thinking of rebuilding my engine myself. Input.
Well my 2001 ITR is currently at 70,000mi and well most likely reach the century mark within a year (yes I drive it alot). It currently burns a good bit of oil and I have been thinking of rebuilding it to stop oil consumption. Of course while I'm in there I plan to bump the compression and do a few other things. Here is my plan.
Pistons- JDM ITR, CTR, or the new probe forged pistons that work with the stock rods.
Stock rods.
ARP rod bolts.
All new bearings and seals.
New head gasket.
I have never rebuilt an engine myself but I have done my fair share of mechanical work and have seen a few engines torn down. I also work in a shop with access to all the nessecary tools and there are two mechanics in the shop that rebuild engines in their spare time. I actually figure starting out on a B18C5 might be a little easier than most. Doing my own labor could keep the price in the $700-$800 range depending on the price of bearings and seals. Your opinions would be appreciated.
I would also like if I should go ahead and get the crank balanced? I don't plan on revving the engine anywhere past 9,000rpms, but it would be nice to do. Again any input would be nice.
Old May 15, 2003 | 05:08 PM
sgT's Avatar
sgT
Default Re: Thinking of rebuilding my engine myself. Input. (ActiveAero)
balance EVERYTHING.
dont needarp rod bolts
manual tells the rest.
Old May 15, 2003 | 05:12 PM
baonest1's Avatar
Default Re: Thinking of rebuilding my engine myself. Input. (sgT)
like sgT told me a while back when i was putting my head together, "you gotta learn sometime". plus it will save you lots of money
Old May 15, 2003 | 06:36 PM
navin's Avatar
How do you go about balancing everything..?
Also wondering if I should build my first motor myself...
Old May 15, 2003 | 06:54 PM
RTW DC2R's Avatar
Default Re: Thinking of rebuilding my engine myself. Input. (navin)
if you have another car you can drive, I say go ahead and give it a shot. As long as you have a manual by your side, disassembly and reassembly shouldnt be too difficult. if you wanna bump the compression, might was well get some pistons(since thats what you were planning already) and also throw in a thin head gasket to add a little more compression. Im not too sure about the balancing process, but I assume thats not something you do in your home garage(unless maybe your name is sgt). But if you take the motor apart, you can take it to the machine shop and have them hone the cylinders, install the pistons, balance everything out, and then you can put it all back together. the manual should be good enough to walk you through it, and HT is here to answer some of the tough questions as well. if you do the disassembly and reassembly, you will save a ton of money. if I get into another project, I plan to do most of the work myself as well and it will be MY first motor build.
Old May 15, 2003 | 06:55 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">balance EVERYTHING.
manual tells the rest.</TD></TR></TABLE>
Are most machine shops compitent enough to balance my assembly or should I be very particular?
Any reason not to get the ARP rod bolts? They are only around $100 if I'm not mistaken.
I also figure since the head will be off this would be a good time to upgrade the valve train with some portflow inners or something similar.
Old May 15, 2003 | 07:04 PM
Evs-One's Avatar
Solbros Owns Me
check all clearances as well...
don't go into the build with a "I think I can do it" attitude.
It's easy...just follow your Helms/Chilton's, whatever manual....simple as pie for a stock rebuild
Old May 15, 2003 | 07:08 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Thinking of rebuilding my engine myself. Input. (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">check all clearances as well...
It's easy...just follow your Helms/Chilton's, whatever manual....simple as pie for a stock rebuild </TD></TR></TABLE>
I definitely will have the manual to guide me, a few friends, and a mechanic or two that I can turn to for questions.
Old May 15, 2003 | 07:18 PM
tonyxcom's Avatar
My first complete tear down and rebuild was my B18C5. Fairly easy with the right tools and a good machine shop.
I just used some common sense and followed the Helms to a T.
Old May 15, 2003 | 07:22 PM
F1Spec's Avatar
rod bolts are about $40-50.
HEAD bolts are the ones that cost $100-130
u do not need rod bolts. head bolts are always good as they're
reusable.
always balance the whole roating assembly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">
I also figure since the head will be off this would be a good time to upgrade the valve train with some portflow inners or something similar.</TD></TR></TABLE>
Old May 15, 2003 | 07:23 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Thinking of rebuilding my engine myself. Input. (tonyXcom)
Oh, and pay good attention when you disassemble the engine.
ALWAYS put all corrolating(sp) bolts in ONE zip lock bag...
ie- put all flywheel bolts in one labaled baggy, etc.
It pays to be organized unless you have built numerous engines and you know what bolt goes where.
Be prepared- don't be in a rush
I built my last 2 engines in my living room where it was nice and warm...lol.
You don't want to build an engine in a cold environment, where the metal will shrink and clearances may be off
Old May 15, 2003 | 08:16 PM
baonest1's Avatar
i have all my bolts in a zip lock bag. or just put them back into the screw hole. oh and keep taking pictures as you go along, just incase you need to put somthing back on but forgot. and makes the reassembly easier.
Old May 15, 2003 | 08:32 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Thinking of rebuilding my engine myself. Input. (baonest)
Any idea for the price of bearings and seals? I'm guessing OEM is recommended.
Old May 15, 2003 | 08:59 PM
baonest1's Avatar
stick with OEM. give len at buranco acura a call. he is always there to help
Old May 15, 2003 | 11:03 PM
ImportReview
Guest
Posts: n/a
haha. Good one Steve.
One of the first things you will see if you buy the normal ARP rod bolts for a GSR or Type-R is that the ARP rod bolts actually torque down LESS than STOCK!
Jeff
Old May 16, 2003 | 04:23 AM
00 FBP ItR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">Any idea for the price of bearings and seals? I'm guessing OEM is recommended.</TD></TR></TABLE>
Yes, ALL HONDA OEM, don't use that cheap taiwan knock off stuff.. Please get everything from Honda.
Old May 16, 2003 | 03:51 PM
Hooch'n's Avatar
Default Re: Thinking of rebuilding my engine myself. Input. (00 FBP ItR)
p1.........CTR pistons, cams!
Old May 16, 2003 | 05:33 PM
tC_Dragon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">
..."you gotta learn sometime". plus it will save you lots of money</TD></TR></TABLE>
my new motto in life. Thank you. hahah.. good perspective.
importdps
Feb 12, 2009 03:21 PM
JDMorgan
Jul 16, 2005 09:25 PM
Vbp6us
Mar 13, 2005 07:48 PM
Nihilation
Apr 27, 2004 12:10 PM
All-Star
Aug 3, 2002 02:00 AM
