Pistons and Rods, Remove and Replace, Is It Straight Forward?
Old May 15, 2003 | 02:23 PM
Fatty_1775's Avatar
Default Pistons and Rods, Remove and Replace, Is It Straight Forward?
When replacing stock rods and pistons with eagle rods and pistons with oversized forged ones, do you just bore and hone the block and remove and replace the pistons and rods and rings? Thanks
Old May 15, 2003 | 02:42 PM
Sonny's Avatar
Default Re: Pistons and Rods, Remove and Replace, Is It Straight Forward? (Autobot_Killer)
It's pretty straightforward as long as you've got the right t ools and access to a good machinist. While you're in there, it is a good time tp replace all of the little things that would be a huge pain in the *** to fix later (rear main seal, bearings, gaskets, etc)
Sonny
Vagitarian
Sep 14, 2012 02:14 PM
NwAmH
May 17, 2007 01:39 PM
d16dcoe45
Sep 27, 2006 05:15 PM
T-RO
Dec 17, 2004 08:36 PM
FoShizzle
Nov 30, 2004 08:53 AM
