Can't get O2 sensor out
Old May 15, 2003 | 01:02 PM
JoshRambo's Avatar
Default Can't get O2 sensor out
Any special tricks to getting the O2 sensor out of a cat?
I am putting a testpipe on and teh sensor will not budge. i have used all the force i can and it hasn't budged.
Old May 15, 2003 | 01:03 PM
RTW DC2R's Avatar
Default Re: Can't get O2 sensor out (Gravity)
u still have the cat on the car or off it? those things are biznatches
Old May 15, 2003 | 01:07 PM
.RJ's Avatar
.RJ
PB Blaster + O2 sensor socket
Old May 15, 2003 | 01:10 PM
Larkin W.'s Avatar
Default Re: Can't get O2 sensor out (RTW DC2)
lots of twisting with handwrench
I hate how the friggin wire builds up resistance as you loosen that bolt
JoshRambo's Avatar
Default Re: Can't get O2 sensor out (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">PB Blaster + O2 sensor socket</TD></TR></TABLE>
is pb blaster a type of wd-40 substance?
and wha is an o2 sensor socket? guess iw ll have to go to the auto parts store quick.
the cat is off. i have it sitting up right not so the wires don't get ruined.
Old May 15, 2003 | 01:12 PM
Larkin W.'s Avatar
oh nm then
If you have the cat off you don't have to worry about the damn wire. I couldn't figure out how to disconnect the Cat sensor from the car when i did my header install 2 months ago. But mine came off (out of the cat) fairly easily.
Suprising to me as my ITR is a 97'
Old May 15, 2003 | 01:38 PM
Asahi's Avatar
O2 sensor sockets suck. Get a 22mm Open ended wrench. Good leverage. ALso HEAT helps.
Old May 15, 2003 | 01:45 PM
yoshi234's Avatar
I shoot brides
Default Re: Can't get O2 sensor out (Asahi)
i'll be replacing the rEEr 02 sensor this weekend
yshi - who hopes a monkEE wrench will work
Old May 15, 2003 | 02:21 PM
JoshRambo's Avatar
Default Re: Can't get O2 sensor out (yoshi234)
ok so i stopped to eat dinner.(mmmm sweet fried chicken)
and realized i can just unclip the o2 sensor.
in this pic i am trying to loosen the nut shaped thing right?
Old May 15, 2003 | 02:32 PM
PM-Performance's Avatar
its a bitch ,man the 02 socket is like a 22mm or so that has a cut in it to slip over the o2 and wont jumble uop thw wires, hard to expplain but we got one .
Old May 15, 2003 | 02:37 PM
Asahi's Avatar
Default Re: Can't get O2 sensor out (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">its a bitch ,man the 02 socket is like a 22mm or so that has a cut in it to slip over the o2 and wont jumble uop thw wires, hard to expplain but we got one .</TD></TR></TABLE>
The splt allows too much flex. 22mm wrench has more leverage and doesn't slip/strip as easily.
Old May 15, 2003 | 03:01 PM
jdmspoonitr's Avatar
1) Wd40 the bitch out of it
2) Let it sit for 10 mins
3) Get out the 22 and pop it loose. It might help if you can have a friend use his foot to stop the cat from moving while you wrench at it.
Old May 15, 2003 | 03:06 PM
RTW DC2R's Avatar
Default Re: Can't get O2 sensor out (jdmspoonitr)
maybe use a pipe or something to put on the end of the wrench/ratchet/whatever for leverage...
Old May 15, 2003 | 03:10 PM
Old May 15, 2003 | 03:13 PM
Spunkster's Avatar
use a propane torch on the surounding bung and pipe/manifold. The key i sheat, penetrating oil and brute strenght.
just avoid the hernia!
Old May 15, 2003 | 04:05 PM
JoshRambo's Avatar
Default Re: Can't get O2 sensor out (Spunkster)
thans for the help. i just ran to sears and picked up a 22mm wrench. and it came right off.
damn i wasted like and hour messing with the thing when i should have been done long ago.
Old May 15, 2003 | 05:52 PM
specie's Avatar
7/8" worked for me.
Old May 15, 2003 | 06:49 PM
SlapSmak's Avatar
Default Re: Can't get O2 sensor out (specie)
righty tighty lefty loosey. might help if you dont use a channel locks to try and get it out, (which from the chunks in the O2, you did)
Old May 15, 2003 | 07:11 PM
F1Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">
O2 sensor sockets suck. Get a 22mm Open ended wrench. Good leverage. ALso HEAT helps.</TD></TR></TABLE>
22mm open wrench is all u need.
Old May 15, 2003 | 07:16 PM
geometro's Avatar
Yeah...what used to look like a nut is what you're trying to take off...
WHat are were you using? Monkey wrench? Pliers?
Lefty loosey, righty tighty.
Liquid Wrench (substitute WD40), let it soak and bust out the GI Joe Kung Fu Grip.
22mm deep socket will certainly help.
If soaking the part with liquid wrench, it's time to bust out the propane torch.
On your next install, a little bit of anti-seize on the threads will help for the next time you need to remove it...
George
JDM-Vic
Apr 29, 2010 05:04 PM
CivicExMaster
25
Oct 15, 2008 07:16 PM
cubism
Welding / Fabrication
Dec 1, 2004 10:39 AM
ldodol
Mar 29, 2003 01:24 PM
R134
Aug 27, 2001 02:08 PM
