***Is a B17a good for boosting???***
Old May 15, 2003 | 08:57 AM
russian_racer's Avatar
Default ***Is a B17a good for boosting???***
I'm talking about a stock internals B17a....is it a good motor for boost (maybe better than a B16 because of the B17's lower compression)?? THANX!
Old May 15, 2003 | 09:07 AM
ViperRedCRX's Avatar
Default Re: ***Is a B17a good for boosting???*** (russian_racer)
from what i hear a b17 is the worst of both worlds. it has a bad r/s ratio.
Old May 15, 2003 | 09:29 AM
TheBestCRX's Avatar
Default Re: ***Is a B17a good for boosting???*** (ViperRedCRX)
i heard it was good for boosting because of the already stock low compression.
the r/s ratio isn't bad. it is 1.64 which is better than b18's but worse than b16's, so i don't see how it could be bad. a b16 has 1.75 or something so it's not that different. so i think it would be a good boost platform.
Old May 15, 2003 | 09:34 AM
RacerBoy's Avatar
Default Re: ***Is a B17a good for boosting???*** (TheBestCRX)
Bad Bad Bad idea! I had an original gsr with the B17A engine it and threw a rod around 130,000 miles. The connection rods don't withstand a lot of force. The cranks however are great. If you are going to boost on them, change the rods/pistons and upgrade the valvetrain. At that point, you could get a B16 block and boost on that instead.
Old May 15, 2003 | 05:23 PM
Default Re: ***Is a B17a good for boosting???*** (RacerBoy)
So B17=no boost or BOOST AT YOUR OWN RISK!!
THANX for all the info!!
Old May 15, 2003 | 07:16 PM
tsjeff's Avatar
umm not to be a pain but where do b17a's come from? never heard of them before.
Old May 15, 2003 | 07:46 PM
blastcrx's Avatar
Default Re: ***Is a B17a good for boosting???*** (d1crx)
92-93 integra GSRs
Old May 15, 2003 | 07:52 PM
Hondasaurs's Avatar
It's has the power of the B16A with the torque of a B18.....the happy median. I've very pleased with my B17A1 swap.
Old May 15, 2003 | 09:16 PM
skud_dusty's Avatar
Default Re: ***Is a B17a good for boosting???*** (B17A Hatch)
i was wondering why i didnt see many boosted b17's...
and now i know why r/s ratio can be a good or bad thing for boost (didnt realize it before)
so if it has a shitty r/s ratio at higher rpms, then the rods usually arent as strong as the same design with a lower r/s ratio correct?
Old May 15, 2003 | 09:20 PM
YumVTEC's Avatar
Default Re: ***Is a B17a good for boosting???*** (skud_dusty)
i can't imagine it being a problem to run a low boost turbo setup on a stock internal b17a if it's tuned right. i'm talking a max of 8lbs of boost. that's not so much force that the rods can't handle it. IMO should be fine with correct tuning.
i'm dropping a b17a in my wife's EF this summer, and we will boost it on stock internals right after that, so i'll let everyone know what happens.
Old May 16, 2003 | 11:12 AM
Default Re: ***Is a B17a good for boosting???*** (YumVTEC)
hey if you could that would be awsome
Old May 16, 2003 | 11:59 AM
ricodemus's Avatar
yeah, plenty of people boost stock b18a/b's with great success, I dont see why a conservative turbo setup on a b17 would be worse. go for it.
Old May 17, 2003 | 12:00 AM
blacksheep's Avatar
Default Re: ***Is a B17a good for boosting???*** (ricodemus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricodemus &raquo;</TD></TR><TR><TD CLASS="quote">yeah, plenty of people boost stock b18a/b's with great success, I dont see why a conservative turbo setup on a b17 would be worse. go for it. </TD></TR></TABLE>
I agree. But if you want to run high boost, I would suggest upgrading the rods and using some good engine management like hondata. Tuning is the key to a long living, and good performing engine.
ITRBOY1433
Oct 10, 2008 03:54 PM
turbob16ef
10
Aug 28, 2005 05:18 PM
huskerpower02
Apr 20, 2005 07:34 PM
HonRex
Dec 8, 2003 06:41 AM
