My Compression Test Results
Old May 14, 2003 | 06:20 PM
95GS-R's Avatar
Default My Compression Test Results
Just finished doing compression test with the help of my father-in-law. Used the procedure from the c-speedracing web site, with the addition of grounding the spark plugs in the wires to the exhaust manifold to avoid distributor coil destruction ... I wasn't sure if popping the 15A ECU fuse did that, or just prevented fuel from spilling into cylinders. Anyway, enough of that ... on to the results:
Cylinder 1: 228
Cylinder 2: 225
Cylinder 3: 230
Cylinder 4: 230
This is a 95 B18C1 with about 110K miles on it.
Old May 14, 2003 | 06:26 PM
EG(6)SR's Avatar
Default Re: My Compression Test Results (95GS-R)
good solid numbers across the board. Hope mine will be that consistant.
VTEC-DA's Avatar
Not bad at all. Pretty high actually. You seem to have yourself a good strong motor. Is it all stock?
Old May 14, 2003 | 06:31 PM
95GS-R's Avatar
Default Re: My Compression Test Results (VTEC-DA)
I have the Injen shorty intake, and an ITR intake cam ... the one with the less aggressive grind.
Motor feels strong ... I would like to mod it some more, but I am not sure if header/exhaust would free up much more power. I am not sure what is holding the car back, I can trap 90mph at the quarter, but the fastest pass was 15.6 before the ITR cam went in.
I have heard with that trap speed I should have a better time.
Old May 14, 2003 | 06:32 PM
TeamTooQuick's Avatar
if you get a header and exhaust that cam will free up a lot of power and let your motor breath better since you have that cam.....
Old May 14, 2003 | 06:33 PM
WiggiE's Avatar
New User
Default Re: My Compression Test Results (EG(6)SR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG(6)SR &raquo;</TD></TR><TR><TD CLASS="quote">good solid numbers across the board. Hope mine will be that consistant. </TD></TR></TABLE>
Old May 14, 2003 | 10:55 PM
96dc2's Avatar
Default Re: My Compression Test Results (WiggiE)
I pull the injector clips for a compression test.
Old May 15, 2003 | 05:20 AM
DR3AM's Avatar
Those are some damn good numbers for a '95 GSR!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GS-R &raquo;</TD></TR><TR><TD CLASS="quote">II can trap 90mph at the quarter, but the fastest pass was 15.6 before the ITR cam went in.
I have heard with that trap speed I should have a better time.</TD></TR></TABLE>
Actually, the performance specs for a stock GSR is approximately 15.5 @ 90 MPH so I think you're pretty close to that. With that trap speed, your time wouldn't be significantly faster, if you know what I mean.
Old May 15, 2003 | 04:54 PM
TerribleOne's Avatar
Default Re: My Compression Test Results (Gizzzer98)
damn Ive got a stock 98 with 50xxx and I thought my 225 across the board was good...
jonyi27
Sep 21, 2013 10:55 AM
sjracer
26
Aug 1, 2013 09:42 PM
djcurtis59
Honda Civic (2001 - 2005)
Jul 4, 2011 12:51 PM
Qwikrex
Apr 11, 2003 09:08 PM
Doogie Howser
Sep 15, 2002 05:26 PM
