.48 T3 vs .48 T3/T4 spoolup????
Old May 14, 2003 | 04:49 PM
BoostedD15B7's Avatar
Default .48 T3 vs .48 T3/T4 spoolup????
Say i have a t3 with a .48 ex and a T3/T4 with a .48 ex with basically the same size wheels......How much slower will the T3/T4 spool? Alot of people tell me that there wont be that big of a difference...anyone know from experience with both?
The reason i ask it im currently running a T3 with .48.....But i have a Turbonetics T3/T4 with a .63 just sitting here.....thinking of getting a .48 housing and converting it so i would get more top end. I know i will loose some spool up time but not sure how much?
Old May 14, 2003 | 05:34 PM
JM Performance's Avatar
Default Re: .48 T3 vs .48 T3/T4 spoolup???? (BoostedD15B7)
Spool up will be the same because the turbine are the same, the power band will be much different though.
Old May 14, 2003 | 06:31 PM
Default Re: .48 T3 vs .48 T3/T4 spoolup???? (00SilverLS)
power band would be moved up higher in rpm and not drop off quick like the T3 right?
Old May 14, 2003 | 07:34 PM
Joseph Davis's Avatar
The compressor wheel is bigger, weighs more, takes more to spin it. It will begin to spool at about the same time, but won't fully spool as quick.
Given the power it will push due to greater efficiency it's a moot point. I think you should try both .48 and .63 turbine housings out on your setup, see how you like both.
Old May 14, 2003 | 08:14 PM
Default Re: .48 T3 vs .48 T3/T4 spoolup???? (J. Davis)
Well i used to have the T3/T4 with the .63 on it because it came with my Drag kit....But that turbo was way too big for my sohc del sol and took way too long to spool....now im running a T3 with the .48 and the spool up time is sooooo much better but the top end isnt near the same.....thats why i wondered about converting the T3/T4 to .48 to get the best of both and go in the middle.
Old May 14, 2003 | 09:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">The compressor wheel is bigger, weighs more, takes more to spin it. It will begin to spool at about the same time, but won't fully spool as quick.</TD></TR></TABLE>
Actually compressor wheels are so light that the difference in size doesn't make any noticable difference. Compressor design is all about efficiency.
Old May 14, 2003 | 10:10 PM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedD15B7 &raquo;</TD></TR><TR><TD CLASS="quote">Well i used to have the T3/T4 with the .63 on it because it came with my Drag kit....But that turbo was way too big for my sohc del sol and took way too long to spool....now im running a T3 with the .48 and the spool up time is sooooo much better but the top end isnt near the same.....thats why i wondered about converting the T3/T4 to .48 to get the best of both and go in the middle.</TD></TR></TABLE>
How much boost are you running with the t3, what are you planning on running with the other?
Just trying to think of a good suggestion...
Old May 15, 2003 | 07:04 AM
Default Re: .48 T3 vs .48 T3/T4 spoolup???? (ion_four)
right now im running 8psi with the T3 but it doesnt have near the top end like the T3/T4. And in a few months im planning on getting inj and hondata and running 14 psi.
Old May 15, 2003 | 07:08 AM
BoostedH23a1's Avatar
quife
Old May 15, 2003 | 08:24 AM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedD15B7 &raquo;</TD></TR><TR><TD CLASS="quote">right now im running 8psi with the T3 but it doesnt have near the top end like the T3/T4. And in a few months im planning on getting inj and hondata and running 14 psi.</TD></TR></TABLE>
At 8psi I would wager that the lack of top end is caused by something else. A t3 should be plenty big for a 1.5l even at 14psi. I really have to believe people go way to big on turbos, which isn't a big deal on a race car, but not as fun on the street, since it takes forever to spool. When I ran one on my 1.6sohc vtec with no exhaust it spooled up pretty quick and had GOOD top end, it just wanted to keep pulling well past redline.
Old May 15, 2003 | 01:09 PM
Well i know that it is running super rich.....that may be causing my loss in top end power.
The other thing is the ex. wheel is clipped for faster spoolup.....Will this affect my top end?
Old May 16, 2003 | 06:34 AM
hmm
Old May 16, 2003 | 10:00 AM
TurboSedan's Avatar
New User
Default Re: (BoostedD15B7)
Running super rich will hurt the entire powerband, especially top-end.
Old May 16, 2003 | 01:55 PM
Does anyone know is clipping the wheel affects top end?
Old May 16, 2003 | 02:13 PM
ion_four's Avatar
I was under the impression that you clipped an exhaust turbine to gain top end at the sacrifice of some additional spool-up time. Since there's less surface area on the wheel it takes more exhaust gas to get it spinning, but it is also less restrictive when it is spooled up.
Old May 17, 2003 | 07:54 AM
Default Re: (ion_four)
cool thanks.
Old May 17, 2003 | 10:34 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I have a .48 T3/T4 Garrett, I was getting full boost at 3500rpm on my 99 Si.
Just trying to give you some ideas on response numbers.
Old May 17, 2003 | 10:39 AM
hulkhb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00SilverLS &raquo;</TD></TR><TR><TD CLASS="quote">Spool up will be the same because the turbine are the same, the power band will be much different though.</TD></TR></TABLE>
exactly correct, seeing as the turbine wheels are the same.
civichbsi1590
Feb 23, 2011 02:12 PM
Mugencrxsir1
Feb 26, 2006 04:17 PM
Kp_VtekNiks
Jul 30, 2003 12:26 PM
SiRkid
Aug 13, 2002 10:14 AM
Ri5e
Aug 24, 2001 07:59 AM
