Dash/Centre Gauge Panel (pics/drawings/misc BS)
Old May 14, 2003 | 04:42 PM
Driven's Avatar
Default Dash/Centre Gauge Panel (pics/drawings/misc BS)
baSorry for the quality of the pictures, but, here they are, as you requested:
First, the pictures:
Behind the gauges
Behind the gauges
Behind the gauges
Front of gauges, the extra hole is for my brake lamp for the camera
Connector for gauges
Measurements/Drawing
Dash Panel/Gauges
Top view of panel, notice the step
Notice the connector. Extra wire is for lighting
Better view of the step
Better view of the step/wiring
Measurements/Drawings
Basic info:
- I used alluminum, it was light and usily pliable.
- I have a chipped ecu, so the speed sensor isn't needed
- The speedo is off by about 10mph, no modification needed to speedo cable
- No fuel gauge
- I didn't have a huge "hole" drill bit, so i drilled 20 little holes around the circle that was to be used as the holes for the gauges, then sanded/grinded them down with a dremel.
- The oil pressure gauge is the only true mechanical gauge i have in the centre.
- The dash panel has a step/recess that's 3/8" deep.
Wiring:
After having 20 some odd wires going this way and that, I ended up going to the junk yard, picking up several wiring connectors and used them as the basis for my panels. The dash panel uses a corner marker harness from an ED8, the centre panel is a connector i cut off the heater core.
I soldered all the ground wires together and the power wires together... creating two thick wires. One wire for the RPM (for tach) and another wire for lighting. Since the corner marker harness only has three wires, i had to add another wire for the lighting on the dash gauges. The heater core wire had enough wires to carry the 4 wires i needed (ground, power, lighting, and water temp signal).
The other end of the harnesses is on the car, in discrete locations as to not make a huge wiring mess behind the dash. I'll take pictures of that when i get my dash back in.
Let me know if you guys need anything else.
Modified by Driven at 6:53 PM 8/19/2003
Modified by Driven at 8:14 PM 3/2/2006
Old May 14, 2003 | 04:43 PM
Driven's Avatar
Default Re: Dash/Centre Gauge Panel (Driven)
Oh, forgot some things:
Centre panel slides UP into the environmental vents. The dash was cut on the bottom and the panel slides up into it.
The panel is then secured with 4 bolts. I'll take a picture of the dash in the next few days.
Old May 15, 2003 | 06:08 AM
Driven's Avatar
oh, and if you want a wiring diagram, i can create one as well, if needed.
Old May 15, 2003 | 06:58 AM
RacerBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">oh, and if you want a wiring diagram, i can create one as well, if needed.</TD></TR></TABLE>
Wiring diagram would be awesome! I want to do something very similar but only use my water,oil, and EGT gauge. Do you have pictures of what it looks like from a distance? I was going to use a 3 pod gauge holder that goes on your dash up front in that little pocket area but I want to conceal it more. Looks great though...I always admire people who custom make things like this and take their time to do write ups. Keep the info coming!
Old May 15, 2003 | 08:27 AM
Driven's Avatar
Default Re: Dash/Centre Gauge Panel (RacerBoy)
Wiring:
Power is taken directly from the fuse box. I simply tapped one of the fuses that doesn't control anything in my car (ie. Sunroof fuse)
Ground, bolted to the steering column
RPM is taken off the wiring harness off the ECU.
Temp is routed thru the firewall to the sending unit.
Lighting is tapped into the factory dash harness.
This is how it looks from a distance. The box below the 3 gauges is a Field VTEC controller.
The 3 gauges would fit in the space just below where they are mounted now.
You can kinda see the old wiring behind the centre console.
I'll take a better picture of the chassis wiring later today or this weekend.
Modified by Driven at 8:21 PM 3/2/2006
Old May 16, 2003 | 10:36 PM
jasonb's Avatar
Your setup is what inspired me to make my own. Here are a few of the one I just made tonight.
Modified by jasonb at 12:03 AM 5/17/2003
Old May 16, 2003 | 10:47 PM
jasonb's Avatar
Hey Kam, which way did you hook up your oil pressure gauge? Tee off the block or run a line from the block to a tee on your firewall?
**** nevermid, just saw you said you have mechanical gauge for oil press ****
Modified by jasonb at 1:46 AM 5/17/2003
Old May 17, 2003 | 09:54 AM
MidoriEK4's Avatar
Default Re: Dash/Centre Gauge Panel (jasonb)
what gauge wire did you guys use? im running into the problem on mine that i wanna use the stock wires but they are 22awg as opposed to autometers 18awg. any suggestion on what i should do? should i make a custom harness for my self?
Old May 17, 2003 | 10:07 AM
Driven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasonb &raquo;</TD></TR><TR><TD CLASS="quote">Your setup is what inspired me to make my own. Here are a few of the one I just made tonight.[/i]</TD></TR></TABLE>
Very nicely done. You definitely took it to a whole new level! Excellent!
I LOVE seeing people taking ideas and improving them and you certainly did this!
My oil pressure gauge is taking pressure off of the oil pressure sensor off the back of the block. i removed the sensor, and bolted it to the firewall where I tapped the line for my gauge.
I would recommend a seperate harness for the gauge cluster, it makes installation/removal that much easier in the future.
Old May 17, 2003 | 10:10 AM
MidoriEK4's Avatar
so i shouldnt use the wires off the orginal harness to power the autometer ones?
Old May 18, 2003 | 01:27 PM
jasonb's Avatar
Kam, can you post a wiring diagram of how you wired your gauges up?
Old May 18, 2003 | 02:33 PM
Blaze45's Avatar
Brrraaaap!
Looks sharp. Do you have more gauges in the dash?
Blaze
Old May 18, 2003 | 02:46 PM
jasonb's Avatar
Default Re: Dash/Centre Gauge Panel (Blaze45)
at the time, no I dont. if someone ever makes a fuel level gauges that works correctly with the stock sending unit, then I'll pick up one.
Old May 19, 2003 | 01:24 AM
MidoriEK4's Avatar
i made a custom sending unit for my autometer fuel gauge.
Old Aug 19, 2003 | 01:44 PM
Torino91LS's Avatar
Default Re: Dash/Centre Gauge Panel (FI CRX Si)
Why don't the pics work???
Old Aug 19, 2003 | 02:23 PM
raene's Avatar
Default Re: Dash/Centre Gauge Panel (kincaidcrxsi)
Because this post is hellaciously old.
Old Aug 19, 2003 | 03:23 PM
SiR Kid's Avatar
New User
Default Re: Dash/Centre Gauge Panel (raene)
3 months is hardly Hellaciously Old...
Old Aug 19, 2003 | 03:59 PM
raene's Avatar
Default Re: Dash/Centre Gauge Panel (SiR Kid)
On this board? 2 weeks is old here
But I was just trying to answer his question
Old Aug 19, 2003 | 04:07 PM
bagged89hatch's Avatar
nice x's is all i see
Old Aug 19, 2003 | 05:49 PM
Driven's Avatar
Default Re: Dash/Centre Gauge Panel (bagged89hatch)
try:
http://www.theballschallenge.com/kam/
Modified by Driven at 8:22 PM 3/2/2006
Old Mar 2, 2006 | 07:31 PM
Driven's Avatar
Back from the dead...
but, there's a reason.
Looking to improve on the original design.
This will be snuggly situated in the dash cluster with the following gauges:
- Tach
- water temp
- oil temp
- fuel level
- oil press.
I'll have warning lamps for:
- CEL
- low oil press.
- high water temp
- high oil temp
I've thought about a shift light... but, I think i can drive well enough and/or have driven my car long enough to know when to shift (aka, not an idiot). But, the possibility is there.
You can see a lot of the sketching on the panel. It was me checking the best layout of the gauges prior to cutting. The four open holes will be enlarged, as they are currently cut at 1 5/8" using a hole saw. I'll have to physically file away (as opposed to powertool grinding) the circles to get them to be more aligned.
Also, the top corners have to be trimmed in order to fit under the stock cluster housing.
I can cover the metal portion with some sort of overlay as well, before reinstalling... CF overlay and tell everyone i got a JDM CF gauge cluster then sell it on ebay for $300.
The panel cost me $19, it's gonna take me 3-4hrs to make it fit perfectly. and I won't have a single gauge pod on the A Pillar or some big ugly tach bolted to the top/side of the dash. maybe one day i'll spend the cash and buy a STACK.
Edit: I'm also redoing the centre gauge cluster to house three gauges and to semi-permenantly mount my lap timer. Don't know what three gauges i'll need outside of what I have...I do have a volt gauge laying around i'll stuff in there, but two more gauges?
Old Mar 7, 2006 | 05:44 PM
Driven's Avatar
Gauges installed:
these were used for just testing. there will be two lights installed, one for water (or oil) temp and the other for CEL. The water/oil temp light will come on at a certain temp.
The panel will also be painted black so it's less intrusive.
Old Mar 7, 2006 | 07:05 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">Back from the dead...</TD></TR></TABLE>
No ****!
Hawkze_2.3
Apr 23, 2012 04:38 PM
93FastLs
Mar 27, 2007 11:14 AM
joshb_
Mar 16, 2007 11:02 AM
ZygSpeed
Feb 1, 2003 05:02 PM
