Profec B .. Do I need a VAC PORT welded on the pipe after the turbo????
Old May 14, 2003 | 02:28 PM
FredoSP's Avatar
Default Profec B .. Do I need a VAC PORT welded on the pipe after the turbo????
Okay I have a Profec A, but I heard you need 3 VAC sources, (Greddy Turbo Kit) i dont want to drill into the charge pipe and weld a VAC port. Someone who has the Profec B said with that, no drilling is needed in the piping.
If anyone has the Profec B and has it installed on a Greddy or Drag let me know, cause if this is the case, Ill ditch the A and get the B. Maybe Im just confused but if someone has pics of there installed Profec A or B with the VAC lines so I could see for myself, it would be awesome.
Thanks guys
Edit: I know u need the internal WG, Intake mani and FPR, so its not like im totally dumb .. Art wasnt 100% sure so Im throwing this out there. He said he needed a VAC port on his Profec A tho.
Old May 14, 2003 | 02:33 PM
FBP Si 2000's Avatar
Default Re: Profec B .. Do I need a VAC PORT welded on the pipe after the turbo???? (FredoSP)
bump
Old May 14, 2003 | 08:00 PM
swrdply400mrelay's Avatar
Hey Fred, I got a Profec B. It came with a threaded nipple. I just drilled that into the intake pipe and it fit a little loosely, so I got some JB weld and it's hard as a rock now. It's been over 8 months and no problems.
Old May 14, 2003 | 11:38 PM
CzanSOHC's Avatar
Default Re: Profec B .. Do I need a VAC PORT welded on the pipe after the turbo???? (swrdply400mrelay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i dont want to drill into the charge pipe and weld a VAC port. </TD></TR></TABLE>
why not? it's easy as hell.
Old May 15, 2003 | 06:16 AM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swrdply400mrelay &raquo;</TD></TR><TR><TD CLASS="quote">Hey Fred, I got a Profec B. It came with a threaded nipple. I just drilled that into the intake pipe and it fit a little loosely, so I got some JB weld and it's hard as a rock now. It's been over 8 months and no problems. </TD></TR></TABLE>
You think you could take a pic of what it looks like, and I need to get one of those things!
Old May 15, 2003 | 06:53 AM
highmilehatch's Avatar
I'm curious as well, whether you have to have the boost source come from the charge pipe before the throttle body or if its ok to run it off the intake manifold.
Old May 15, 2003 | 08:33 AM
Ok here's how I got it setup:
Old May 15, 2003 | 09:46 AM
FredoSP's Avatar
Cool thanls! But what goes to the wastegate (I know another VAC line) but if that one off the FPR line?
Old May 15, 2003 | 10:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">Cool thanls! But what goes to the wastegate (I know another VAC line) but if that one off the FPR line?</TD></TR></TABLE>
It's the other vacuum line off the stepper motor (the black box). The VAC line off the FPR goes to the Profec unit itself. Let me know what you do
Old May 15, 2003 | 12:59 PM
So it goes the same way the greddy web page tells you. Would you want to put the nipple after the intercooler to compensate for the pressure drop?
zach1288
Jan 7, 2009 09:49 AM
ForceFed Motorsports
May 6, 2008 11:47 AM
vboy714
Jun 7, 2006 11:44 PM
SPOON_BeIgHtEeNsEe
Apr 29, 2006 04:01 AM
max boost
Nov 20, 2003 11:14 AM
