"brake" cluster light wont go off?
Old May 14, 2003 | 12:14 PM
'94gsR's Avatar
New User
Default "brake" cluster light wont go off?
the brake light in the instrument panel never goes off. it stays lit like i have my emergency brake on. anyone?
Old May 14, 2003 | 12:40 PM
gsrhunny's Avatar
Default Re: "brake" cluster light wont go off? ('94gsR)
Check your brake fluid level. If its good don't worry about the light. I was told by acura that its do to a faulty sensor in the reservoir (however you spell it). Mine ussually goes off when I move the sensor around. If the light really bothers you check into a new sensor.
Old May 14, 2003 | 12:52 PM
The-LS's Avatar
check your pads and reservior level.
Old May 14, 2003 | 12:54 PM
WiggiE's Avatar
New User
Default Re: "brake" cluster light wont go off? (Black-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS &raquo;</TD></TR><TR><TD CLASS="quote">check your pads and reservior level.</TD></TR></TABLE>
Then if neither work, replace your reservoir cap.
Old May 14, 2003 | 01:19 PM
UnionCity LS's Avatar
Old May 14, 2003 | 01:51 PM
SMZ GSR's Avatar
Default Re: "brake" cluster light wont go off? (UnionCity LS)
ryan, most likely your brake fluid.
Old May 14, 2003 | 05:15 PM
Hairy Gorilla's Avatar
I've got an idea. Use the search feature. We just went over this 2 days ago...and the exact same question probably 2 weeks before that...
https://honda-tech.com/zerothread?id=502157
Old May 14, 2003 | 05:37 PM
Chris's Avatar
Default Re: "brake" cluster light wont go off? (Tim Maryak)
also this is important as well..
CHECK the PADS.
When the pads wear (thin) it takes more fluid out of the reservior and into the caliper itself, causing low fluid conditions.
If you just filled up the reservior, when you went to put in new pads the res will overflow.
So, remember to look at the pads first, then check the fluid level, then if not that, make sure the wires are connected to the top of the lid.
Dav94Lx
Aug 30, 2007 11:58 PM
maluseanjohn516
Dec 31, 2005 03:10 PM
ham_yorkwind
Apr 10, 2005 07:43 PM
whitehf
Feb 12, 2005 06:32 PM
DragII
Jun 6, 2004 08:54 PM
