E Brake light won't shut off
I checked out the mechanism on the ebrake itself, it's plugged in. but when the button is pressed, its not cutting off the light. Where is the rest of this circuit?
Re: E Brake light won't shut off (DragII)
Check your PADS if your Pads are worn low the light will turn on to indicate low Fluid but actually it is due to the worn pads. Many people will just add fluid and fail to check the pads and then that AWFUL grinding noise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragII »</TD></TR><TR><TD CLASS="quote">I checked out the mechanism on the ebrake itself, it's plugged in. but when the button is pressed, its not cutting off the light. Where is the rest of this circuit? </TD></TR></TABLE>
mine is the same way, ever since my girlfriend hit I tire in the road that damn thing is stuck on, but every once in a while it will go off then right back on again.
Re: E Brake light won't shut off (Tsukuba 699)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tsukuba 699 »</TD></TR><TR><TD CLASS="quote">Check your PADS</TD></TR></TABLE>
Re: E Brake light won't shut off (jond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond »</TD></TR><TR><TD CLASS="quote">check the brake fluid level
Re: E Brake light won't shut off (ITR764)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR764 »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
No!!!!!!!!
No!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragII »</TD></TR><TR><TD CLASS="quote">brake fluid is fine, its the pads thanks guys.</TD></TR></TABLE>
