Cylinder Questions??
Old Jul 9, 2001 | 12:18 PM
ringgold's Avatar
Default Cylinder Questions??
I had to take the head off my car recently and havent got it back on the car yet. The question is when I was sitting and looking at what is left of the engine in my car I noticed a small bit of rust in 2 of the cylinders I wiped them down and sprayed some WD40 in them is that gonna hurt anything because I didnt have anything else at the time. Hope I can get this thing back together soon.
Old Jul 9, 2001 | 12:28 PM
92Si's Avatar
New User
Default Re: Cylinder Questions?? (ringgold)
I used carb cleaner with most anything that I do with my engine work that involves cleaning, because it evaporates away and doesn't leave a film. I don't know from experience if WD-40 will cause any damage, but I DO know from experience that carb clenaer is pretty harmless.
Old Jul 9, 2001 | 04:10 PM
ringgold's Avatar
Default Re: Cylinder Questions?? (92Si)
Thanks I should have thought of that being that I have also cleaned alot of stuff with carb cleaner. Ill get a couple cans and try it out Im sure it will work.
Old Jul 10, 2001 | 12:57 PM
keithv's Avatar
A lot of machine shops put WD-40 on cylinder walls after a block has been cleaned and honed. I don't think WD-40 will hurt...
1988dxsedan
Engine Machining & Assembly
Sep 3, 2018 09:58 AM
JRLeask
Aug 24, 2014 10:14 AM
B18C_eg
Dec 18, 2006 05:38 PM
gsp ej1-em1
Aug 14, 2006 09:06 AM
92_civic
Welding / Fabrication
Apr 29, 2005 04:52 PM
