TDC mark on crankshaft pulley..
Old May 14, 2003 | 09:30 AM
pg_thao's Avatar
Default TDC mark on crankshaft pulley..
what color is the tdc mark on the crankshaft pulley on a d16z6?.. is it the white one also what degree should i set the ignition timing..
Old May 14, 2003 | 10:21 AM
keithv's Avatar
Default Re: TDC mark on crankshaft pulley.. (pg_thao)
this doesn't answer your exact question, but on my friend's b20, the white mark is TDC and the red one was 16 degrees (and it had a mark for 14 degrees and 18 degrees). look to see if you see a mark on either side of the white mark. if you don't, its probably TDC then.
kdawgy2k1
Mar 26, 2006 08:11 AM
shingles
Mar 23, 2004 07:41 PM
SoCaLNaTIvE
Aug 10, 2003 12:44 PM
b18c-93
Dec 2, 2002 08:02 PM
USDM 4G VTEC
Jun 21, 2002 10:08 AM
