battery location changing on a CRX? Corrosion on CAI! HELP ME!
Old May 13, 2003 | 06:05 PM
GroundZer0's Avatar
Default battery location changing on a CRX? Corrosion on CAI! HELP ME!
Hey, i got a CRX HF 91. Currently the battery is placed in the front left, and the problem is, my short ram intake is kinda resting near it or on it. At first, i didnt think this was a prob, but now, the other day i looked and there is all this white powder on my short ram intake!! I was wondering, how/where can i move the battery elsewhere in the engine bay where it would be in a good location, out of the way of CAI and Short Ram Intakes? Please, any info would be awsome. pics would be too! Thank you.
Old May 13, 2003 | 06:25 PM
GroundZer0's Avatar
Default Re: battery location changing on a CRX? Corrosion on CAI! HELP ME! (GroundZer0)
Oh sorry, also the engine is DOHC ZC. Thanks
Old May 13, 2003 | 06:30 PM
sikcrx80's Avatar
man i am telling u know ture battery or move to back of car..
i had fire under my hood one day on the way to work..
one day i was on my way to work and i passt a couple of cars and then bam
car stalled so i pulled over and the next thing i see is smoke from the front of engine bay
so i tryed to open my hood and i couldnt because i needed some to push down on it at same time... but some one came along from work and stoped and helped me..thank god
well the + side of batter hit me - intake and shorted out and started on fire...
not cool
turn battery man i did
Old May 13, 2003 | 06:34 PM
Foowee's Avatar
Default Re: battery location changing on a CRX? Corrosion on CAI! HELP ME! (sikcrx80)
do you mean to turn the battery 90 degrees?
Old May 13, 2003 | 06:35 PM
GroundZer0's Avatar
^^ Goddamn! Translation please!
I got some of that. So how did you go about moving it to the back of the car? Is there anywhere in the front of the car i can move it to? Let me know. Thanks.
Old May 13, 2003 | 06:36 PM
Mr.SpiLLz's Avatar
Instead of the relocation go to autozone, get a red and black battery rubber cover, and put it on the metal, tape it with electric tape if need be.. Either way it will prevent that from happening because it will lay between the battery and the intake...
Old May 13, 2003 | 06:43 PM
GroundZer0's Avatar
Default Re: battery location changing on a CRX? Corrosion on CAI! HELP ME! (MrSpiLLz)
Could you tell me "what did happen"? What is the white corrosion on my short ram? Can i get it off? Also, i would kind of like to get the battery out of that location anyways, it seems to get in the way of alot of things? Would turning it 90 degrees help?
Also its not so much the cables or connections touching the Short Ram, its the edge of the battery, thats why im wondering where the hell this corrosion came from'?
Old May 13, 2003 | 06:54 PM
bluecrxsi's Avatar
just move your battery to the trunk. i did and havent had a problem yet. mine used to arc around whatever i put between the terminal and intake.plus frees up more room for a swap. it just cleans up your eng bay!
Old May 13, 2003 | 07:01 PM
sikcrx80's Avatar
sry i meant turn battery 90 deg.
yeah i have b16a in my CRX and i have in the back right now but i think im having a voltage prob now when cranking over. so im putting it back in front and with me DC headers it gives off more heat and battery will stop most of it when in front.
Old May 13, 2003 | 07:06 PM
RenoRacing's Avatar
here's where i put mine. It wouldn't work if you had the traditional cold air intake but with shortram it works great and the weight is still over the wheels.
Old May 13, 2003 | 07:28 PM
MidoriEK4's Avatar
Default Re: battery location changing on a CRX? Corrosion on CAI! HELP ME! (HavokRacing)
or like thise.
Old May 13, 2003 | 10:28 PM
Racer613's Avatar
With the swap I have chosen, I have no choice but to relocate to the hatch, where can I find a good one, in black, and if someone with the talent to do so..please post a pic of how one is done correctly, you guys, ROCK!!!
Old May 13, 2003 | 10:51 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: battery location changing on a CRX? Corrosion on CAI! HELP ME! (Racer613)
I like the T1 idea.
Old May 14, 2003 | 02:06 PM
sikcrx80's Avatar
Default Re: battery location changing on a CRX? Corrosion on CAI! HELP ME! (NA CRX Si)
wow thats a small battery. what kind is it?
Old May 14, 2003 | 02:17 PM
.Ryan's Avatar
Don't Trust Anyone
Type One Racing.
Old May 14, 2003 | 02:18 PM
Swift's Avatar
imo the back is the best place to go in order to distribute weight more evenly to all the wheels, but more importantly from front to back. As far as your intake, yeah the stuff will come off but I suggest pouring some coke or other soft drink on it to neutralize the battery acid first before you wash it off.
Old May 14, 2003 | 02:19 PM
wuhungsixxx's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HavokRacing &raquo;</TD></TR><TR><TD CLASS="quote">here's where i put mine. It wouldn't work if you had the traditional cold air intake but with shortram it works great and the weight is still over the wheels.
i just moved mine there yesterday...got rid of the heavy *** Optima i had in my hatch and bought a tiny *** 13lbs Hawker Genisis
Old May 14, 2003 | 03:34 PM
silverCRXTC's Avatar
Default Re: battery location changing on a CRX? Corrosion on CAI! HELP ME! (Swift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swift &raquo;</TD></TR><TR><TD CLASS="quote">... I suggest pouring some coke or other soft drink on it to neutralize the battery acid first before you wash it off.</TD></TR></TABLE>
uh... no, soda is carbonic acid, us a solution of sodium bicarbonate (baking soda) and water. This will evolve carbonmonoxide gas as the sulfuric acid is netralized. the other way just adding fuel to the fire. Also never just pour add slowly because alot of acid and some water (less parts than acid) = heat, a lot.
chase7687
Mar 30, 2009 03:34 AM
snezze21
Sep 26, 2005 07:24 PM
twincamrex
12
Oct 2, 2002 08:41 PM
.MilanoRex
Apr 25, 2002 10:27 AM
