speedbleeder size for clutch fluid bleeding?
Old Jul 9, 2001 | 06:28 AM
owen_the_soyboy's Avatar
Default speedbleeder size for clutch fluid bleeding?
did a search but couldnt find the answer...
G3 clutch fluid bleed screw... I want to get a speedbleeder for this.
anyone know if it's the same size as G3 teg brake caliper bleed screws?
thanks.
Old Jul 9, 2001 | 06:58 AM
Ubermensch's Avatar
Default Re: speedbleeder size for clutch fluid bleeding? (owen_the_soyboy)
I need to know as well. Somebody, anybody....
Actually I was wondering if bleeding the clutch was really necessary. I know I have some air in the system, but I don't mind the feel of the clutch being a little soft. Is there some other reason I should bleed it? (i.e. air allows corrosion, or earlier clutch wear...)
Old Jul 9, 2001 | 08:08 AM
Default Re: speedbleeder size for clutch fluid bleeding? (Ubermensch)
I am bleeding it a fourth time innn two months because the fluid is black after a few weeks of driving.. and I want to clean that stuff out.
maybe I am going overboard, or maybe I need a new slave cylinder....
but a speedbleeder would make this a hella lot easier...
Old Jul 9, 2001 | 10:32 AM
Ubermensch's Avatar
Mine dropped a little low. I noticed some black goo also. Let me know if you come up with a good solution short of flushing it repeatedly.
hondaless
Apr 2, 2009 08:58 AM
RusBear
Jul 10, 2008 11:08 AM
redline7
Feb 17, 2008 12:24 PM
tytyguy
Dec 3, 2005 02:32 AM
blklude
Jun 16, 2003 10:08 PM
