upgrading to stainless steel valve?
Has anyone upgraded to stainless steel valve in a boosted engine (turbo)?
should it be done if I am boosting around 15psi daily and 20psi occassionally?
I have the block sleeved and rebuild, in case you are wondering
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bsmoak »</TD></TR><TR><TD CLASS="quote">My opinion:
Its only worth it if you go oversized.</TD></TR></TABLE>
Actually its worth it for exhaust with stock size.
Lighter, which means less reciprocating mass in the valve train. You can rev quicker, and safer.
The true value of stainless valves is to be able to withstand the cylinder pressure and temperature that high boost applications experience.
For my d-series race car I am going to start building this summer I am going to use inconel valves to withstand the 30+psi.
inconel valves is the way to go. if you have high heat its the best period. that with some titanium springs and retainers are the ultimate setup but expensive as hell
what do you guys think of this valve train setup?
crower dual springs
crower titanium retainers
crower stock sized stainless steel sworl poished valves
thats what i am using... what do you think?
crower dual springs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostin b16 »</TD></TR><TR><TD CLASS="quote">what do you guys think of this valve train setup?
crower dual springs
This is the setup I am looking at. Is this a good setup?
I guess it's not that important for me to have them when I am running 15psi?
Modified by chusai at 12:30 PM 5/14/2003
crower dual springs
rich7777
Oct 24, 2011 09:26 AM
