getting 60 miles/tank of gas!!!
Old May 13, 2003 | 12:09 PM
fcuked's Avatar
Default getting 60 miles/tank of gas!!!
I just swapped an obd1 gsr motor into my 93 dx, i haven't wired up vtec yet (no time) but my car is running rich as hell, i have to fill up almost every day with 91 octane and it only lasts for 60 miles. WTF is it...i had that same motor in a 95 civic which was written off and the motor didn't do that. By the way the motor wasn't touched by the accident, it just sat in my garage for a month.
Old May 13, 2003 | 12:11 PM
eg6ajk's Avatar
Default Re: getting 60 miles/tank of gas!!! (Junior.)
pop open the plugs and check them out. maybe there is another culprit as in gas leaking from the tank or fuel rail?
how are the plugs? really wet? what ECU? tried changing the injectors to DX ones???
STN_Pat's Avatar
hole in the gaz tank
Old May 13, 2003 | 12:15 PM
fcuked's Avatar
Before is swapped the motor , my dx gave me about 700km/per tank so i doubt it's a leak.
Eg6, you are a local is there any possible way you could look at it tonight???
Old May 13, 2003 | 12:17 PM
HyBriDcxR's Avatar
Default Re: (STN_Pat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STN_Pat &raquo;</TD></TR><TR><TD CLASS="quote">hole in the gaz tank </TD></TR></TABLE>
That's a thought.
Do you have a heavy foot? Or you're running extremely rich.
Old May 13, 2003 | 12:19 PM
fcuked's Avatar
Default Re: (HyBriDcxR)
it barely idles, every time i come to a stop the car stalls so i had to adjust the tb cable that it's always giving a bit gas.
4DeepCivic's Avatar
Put up a sign by your car... No open flame closer than 1000 Ft.
Check your fuel system. What ECM r u running?
Old May 13, 2003 | 06:33 PM
MLogan's Avatar
Someone is stealing gasoline from you.
zx2gotboost
Mar 21, 2006 07:16 PM
Andres-eh2
35
Nov 20, 2004 08:39 PM
LS_teg07
Mar 12, 2004 04:53 AM
fcuked
May 17, 2003 03:47 AM
phoboyjimmy
11
Nov 13, 2002 07:48 PM
